Indicators Have Stopped Working
Posted 10 March 2010 - 06:37 PM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model:Mayfair
Year:1991
Hi Guys,
My indicators have stopped working, everything on the same circuit is still working so I know the fuse is fine. The indicator flasher unit is also fine as is my hazard warning switch. Where do I look for the problem next? Is it at the stalk? Everything on the same stalk still works also. Please help guys I am at a stand still.
Any non-standard parts that might be involved with the problem?No
Posted 10 March 2010 - 06:57 PM
Posted 10 March 2010 - 07:25 PM
I have tried changing the switch but that hasn't changed anything.you could try the stalk but id try another hazard switch first just because the harards work doens tmean its not the switch as the indicators go mthrough the switch.
Posted 10 March 2010 - 07:30 PM
Posted 10 March 2010 - 07:53 PM
yeah they both work fine.minis have 2 flasher units one behind the dash one under the bonnet have you check both mate.
Posted 10 March 2010 - 08:30 PM
how do you know they work fine?
Posted 10 March 2010 - 08:35 PM
Hazard flasher unit works fine because the hazards still work and the indicator flasher unit works fine because I have tried 2 new ones ( brand new out of the packet ) and neither of those get the indicators working either. Does anyone have any ideas?yeah they both work fine.minis have 2 flasher units one behind the dash one under the bonnet have you check both mate.
Posted 10 March 2010 - 08:40 PM
Posted 10 March 2010 - 09:02 PM
Does anybody have any ideas? I'll be greatful for any ideas at all.fair doos mate, my indicators done this and that was the problem. good luck
Posted 10 March 2010 - 09:04 PM
Posted 10 March 2010 - 09:59 PM
Posted 13 March 2010 - 08:36 AM
Thanks Punts,If Ive got the right model. The feed to the stalk goes:- fuse-(green wire) to flasher unit, flasher unit-(light green/brown wire) to hazards switch, hazards switch-(light green/brownwire) to stalk, stalk-(green/white wire) to l/h side, (green/red wire) to r/h side. Check the wires into and out of the hazards switch, if they're ok, check the feed (LG/Br)at the stalk plug, loom side. Then continuity between LG/Br and G/R with the stalk in L/H indicator position then LG/Br and G/R with stalk in R/H indicator position.
Only problem is I am not fantastic with electrics as I am teaching myself. I am learning but rather slowly ha ha ha. So my next question is how do i check the continuity? The way I read it, it must have something to do with the voltage between the different wires. If I am correct how do I check this?
Any info or advice would be great.
Cheers guys
Deano.
Posted 13 March 2010 - 03:33 PM
