How Do You Get It Off
Posted 10 March 2010 - 06:43 PM
this may sound stupid but ive got a wing mounted aeriel but it doesnt work so i tried all day to get it off and have no luck how do you get it off thanks dan
Posted 10 March 2010 - 06:47 PM
Posted 10 March 2010 - 06:48 PM
thanks when i locked there was no sign of any nut bolts or anythinkThere should be a nut and washer connected to the body of the aerial underneath inside the wing, which you can then take off, allowing the aerial to be removed
Posted 10 March 2010 - 07:29 PM
Once you take it off the aerialdrops down through the hole.
Posted 10 March 2010 - 07:30 PM
ok thanks ill go have a look now thanksThe nut should be on top of the wing, so visible from above!
Posted 10 March 2010 - 08:06 PM
got it off thanksThe nut should be on top of the wing, so visible from above!
