Idler Gear End Float
14 replies to this topic
#1 mini-geek
mini-geek
  • 1,169 posts
Posted 10 March 2010 - 10:34 PM
I'm building up my 1380 it's a different block but the original gear box and transfer case that I used with the last engine, this all worked fine with no problems, but I have been building it back up and when I checked my idler end float I get 10 thou.
so I have took it apart again, and my thrust washers are 133 and 136 so they aren't the thinnest of shims so why such a big end float? is it something more serious or should I just buy some thicker thrust washers and not be too worried about whay it did have such a large tolerance?
any advice please...... I need to have this engine in a running in 4 weeks
#2 MRA
MRA
  • 7,607 posts
Posted 10 March 2010 - 10:46 PM
0.136" is not the thickest :thumbsup: 0.139" is 0.003" thicker and a 0.134" thrust washer means that you have 0.006" clearance which is about central :) ie 0.004 to 0.007" "gap"
#3 mini-geek
mini-geek
  • 1,169 posts
Posted 10 March 2010 - 10:57 PM
yes I know they are not the thickest they do, I was looking at getting this http://minispares.co...amp;title=IDLER GEAR SHIM .138/.139...
I would use that shim and and the 136 that I have, so that would be a 136 and a 138 by my calculations that would reduce end float by 5 thou
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 March 2010 - 07:46 AM
Question is, how did you check the end float ?
#5 mini-geek
mini-geek
  • 1,169 posts
Posted 11 March 2010 - 05:52 PM
using a DTI and a lot of patience to make sure it wasnt giving a false reading by slipping off the teeth.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 March 2010 - 05:56 PM
That just tells me how you got the number, does not tell me how you measured the endfloat..
#7 mini-geek
mini-geek
  • 1,169 posts
Posted 11 March 2010 - 05:59 PM
by building up the gearbox and casing with a gasket and moving the gear side to side
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 March 2010 - 06:05 PM
So gearbox, gasket and transfer case, no engine block, transfer to gearbox bolts torqued up to 18lbft ?
so you could put a feeler gauge between the idler gear shim and the gearbox case if you wanted to ?
#9 mini-geek
mini-geek
  • 1,169 posts
Posted 11 March 2010 - 06:24 PM
no I had the gear box on the engine as I had already built that up then rememberd the idler end float
the bolt's where all tourqued up and I have also removed it and refitted it with a diffrent gasket in case that was the problem, but with no luck.
I know it's not the preferd way of checking it but I have esured my mesurments were spot on.
#10 MRA
MRA
  • 7,607 posts
Posted 12 March 2010 - 10:37 AM
I also am a little confused >_< how did you get the feeler gauge in to measure the clearance ? did you use the hole that the primary gear fits in to ?
#11 GraemeC
GraemeC
  • 7,467 posts
Posted 12 March 2010 - 10:51 AM
He said he used a DTI, not a feeler gauge.
#12 mini-geek
mini-geek
  • 1,169 posts
Posted 12 March 2010 - 06:20 PM
so have I checked this correctly or not?
#13 minimans
minimans
  • 411 posts
Posted 03 April 2017 - 10:57 PM
I would recheck the end float again. I don't see how you could get the DTI on the Idler gear correctly through the primary gear hole?
#14 GraemeC
GraemeC
  • 7,467 posts
Posted 04 April 2017 - 05:50 AM
7 years on I think he might have found other things to worry about by now!
#15 minimans
minimans
  • 411 posts
Posted 04 April 2017 - 07:53 PM
It took me a while to think about it....................................Must remember to check dates in future.........................
