Engine Bay Cleaning
9 replies to this topic
#1 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 11 March 2010 - 10:01 AM
Just aquired a 93' k mini sprite 1275cc carbed. My mate has just recently changed an oil pipe the comes off the filter housing to a braided one as its quite common for stock one to leak some what and is has done by leaving an oil mist over engine and grill area.
Can i simply go at with some gunk then wash off with water etc? obviously being careful of electrics and that!
or is there a better way?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 March 2010 - 10:05 AM
without lifting the engine, yes gunk is ok...
Not sure what you mean about the pipe leaking, this probably means it's been removed at some stage and not refitted with either annealing the copper washers or putting new ones in...
They don't normally leak...
#3 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 11 March 2010 - 10:25 AM
Thanks will go easy with gunk and careful where it all goes and that!
Its the one in link below from mini spares, sounds like on this engine its a common problem, it wasnt leaking like dripping i dont think more spraying a mist everywhere! not cheap this one so hope it works and now goes better to hehe!
http://www.minispare...=...ED OIL FE...
#4 Ipod
Ipod
  • 2,024 posts
Posted 11 March 2010 - 11:59 PM
MUCOFF >_<
#5 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 12 March 2010 - 12:22 AM
i would use gunk >_<
#6 Ipod
Ipod
  • 2,024 posts
Posted 12 March 2010 - 12:36 AM
i would use gunk :)
I used gunk for the easy to brush bits... and mucoff for awkward bits >_<
#7 dazzler-pws
dazzler-pws
    Previously known as ringonezero
  • 167 posts
  • Local Club: Minifinity
Posted 12 March 2010 - 08:47 AM
£9 will buy you 5ltrs of our degreaser, F-ing brill stuff!
#8 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 12 March 2010 - 09:21 AM
Thanks for replies guys i have a newish can of gunk so will try that first! would i be best of removing any components first or
just be careful around anything in particular? obvious ones being dizzy and coil etc or any switches in engine.
I have the later electronic dizzy to so see a little control box on side so be careful of that!
#9 MattDuffy88
MattDuffy88
  • 14 posts
Posted 12 March 2010 - 09:55 AM
AutoSmart 'Tardis' or AutoGlym Engine & Machine Cleaner will get rid of the oil >_< Tardis is great for getting rid of tar spots and glue residue too.
#10 Ipod
Ipod
  • 2,024 posts
Posted 12 March 2010 - 07:09 PM
After give it a good spray/coating of Wd... ;)
