Power Boost Valve Location
8 replies to this topic
#1 Spannerhead
Spannerhead
  • 147 posts
Posted 11 March 2010 - 11:11 AM
I've just posted this question in the wrong section, it's in the main techie section. But if anybody has any pictures of the location of there's please do let me know.
#2 mykweb
mykweb
  • 566 posts
  • Local Club: does here count :)
Posted 11 March 2010 - 12:45 PM
Have a look at page 3 of my post, Mpi spluttering under acceleration, I have placed my PBV beside teh brake servo
Mike
#3 Spannerhead
Spannerhead
  • 147 posts
Posted 11 March 2010 - 03:46 PM
Thanks Mike, exactly where I thought it would go!!
#4 shpoom23
shpoom23
    Just On Tickover
  • 9 posts
  • Local Club: West Sussex Mini Owners Club
Posted 15 March 2010 - 09:16 PM
Attached File  engine_Jan_2008__13_.JPG   2.27MB   57 downloads
or you could put it here
#5 sterrey
sterrey
  • 44 posts
  • Local Club: Medievil Minis Warwickshire
Posted 16 March 2010 - 05:01 PM
Do the Boost Valves make much difference to the performance of a standard MPI Cooper Sport with K&N and 3" tail pipe (with catalytic converter)?
#6 mykweb
mykweb
  • 566 posts
Posted 17 March 2010 - 12:54 PM
From what I am aware the Valve does not "boost the power" it mearly steps up the pressure on the fuel rail to compensate for a larger demand for fuel from a larger head.
Only thing you are likely to see on a standard mpi would be a slightly quicker uptake on acceleration on teh car. But this will be ver very minimum.
Personlally I would not waste the £80 on this if your car is standard, or if you have a tuned car that is not having issues.
As I said in my post I used to run a stage 3 mpi, sw5i cam, 1.5.1 rockers, alloy TB and k&n for arond 2 months. The car used to run like a dream, infact even better than it does now. One day I drove to work and it was spluttering all over the place. Installing the Pressure Valve resolved these issues.
Mike
#7 sterrey
sterrey
  • 44 posts
Posted 19 March 2010 - 06:54 PM
Mike
Hi Mike, Thanks for the advise
Alan
#8 sirweste
sirweste
  • 75 posts
Posted 21 March 2010 - 10:31 AM
have you ever had your car on a rolling road and had the fuel mapping worked out? Was there a definite improvement in torque? A simple series resistor on the air temp sensors seems to put the fueling on mine up significantly, to be honest I unclear of the need for the new pressure regulator...
#9 mykweb
mykweb
  • 566 posts
Posted 21 March 2010 - 05:54 PM
All this does is fool the car to over fueling, by thinking its sucking in air colder than it is. Basically BAD, with a capital B A D
this does not up the fuel pressure, it over fuels the car. Not really the same. Infact you can get the same result buy removing the Green sensor plug from the inlet manifold. The car will then default on the ECU.
My issue with my car was pressure related, and this can only be solved by fitting a bigger fuel pressure valve and the largest you can get for the mpi is 3.0 bar.... or fit and adjustable one :dontgetit:
Mike
