Leaking Sump Plug
Posted 11 March 2010 - 10:45 PM
Should I just MTFU a bring on the 2 foot breaker bar?
Posted 11 March 2010 - 10:49 PM
Edited by taffy1967, 11 March 2010 - 10:50 PM.
Posted 11 March 2010 - 10:51 PM
Posted 11 March 2010 - 11:08 PM
Posted 12 March 2010 - 12:03 AM
and tightened it as tight as possible with a short socket handle.
Torque wrenches exist for a reason. Hard steel screw, soft alloy housing, large diameter course thread. Not good combined with excessive force. Are you sure the washer is centred and was new? You could anneal it, or use a composite washer as said above. Sounds like the thread may be stretched though to be honest.
Yes. If you want to break it further.
Helicoils can be re-set but if the new outer thread that the Helicoil sits in has been stretched there's not a lot that can be done. I'd try a composite washer in your position.
Posted 12 March 2010 - 01:56 AM
However, the bonded seals may not work with a sump that's already HeliCoiled as the HeliCoil diameter MAY be larger than the area where the rubber is on the bonded seal. Still, it's worth a try. In the U.S. these are stocked as generic parts and I buy them to fit 14mm diameter drain plugs. They are a very snug fit on the Mini's 5/8" plug but they will go and will seal on sumps without a HeliCoil. As an alternative, you may find a hydraulic hose fitting store has sealing washers for 3/8" BSPP (G thread) hose fittings. They will be larger than those for 14mm drain plugs and they may work on HeliCoiled sumps.
You could also see if the local parts store has the "ribbed" nylon drain plug washers. These aren't as good as the bonded metal/rubber seals but they cover a larger area and like the bonded seals they will allow you to achieve a seal with less torque than the copper washer.
Posted 12 March 2010 - 09:09 AM
It's not centred - very hard to do as the ID is much larger than the sump threads. It was new bought from mini spares.
Is there a way of quickly taking the plug out and changing the washer without replacing all the oil?
Posted 12 March 2010 - 11:28 PM
Cheers guys,
Yes you have to drain all the oil and then refill it. Or perhaps lifting the car on it's side will help prevent any oil drainage?
Posted 12 March 2010 - 11:40 PM
Posted 13 March 2010 - 12:22 AM
Can I just refill it with the oil that comes out, its only a week / 50 miles old. Or is that a cardinal sin?
As long as the bowl or whatever you use to drain it is nice and clean, then it'll be fine.
Posted 13 March 2010 - 06:28 AM
Sump plug torque 25lbft
Posted 13 March 2010 - 08:57 AM
