mini 1000 1975
mini 998 mayfair 1989
just a quick one.
what size is the hub nut (the nut with the pin holding it in place) for both the mini's above?
cheers
Hub Nut Size?
davexdavexdave
, Mar 12 2010 10:17 AM
6 replies to this topic
Posted 12 March 2010 - 10:17 AM
Posted 12 March 2010 - 10:32 AM
Pretty sure 1.5"
Posted 12 March 2010 - 10:34 AM
Depends,
Front or rear, Disk or drum.
and no it's definitely not 1.5"
Unless you mean the ball joint which is not a hub nut !!! lol
Edited by Guess-Works.com, 12 March 2010 - 10:35 AM.
Posted 12 March 2010 - 10:35 AM
either 1"5/16 or 34mm
Posted 12 March 2010 - 10:53 AM
For the early car, the front hub nuts are either 1 & 1/8" or 28mm. For the late car they are either 1 & 5/16" or 34mm. That doesn't mean that the sockets are interchangeable on the nuts, it means that both metric and imperial nuts are avilable for the front hubs (all are imperial threaded) and either one socket or the other is correct for each car. There is no easy way to tell whether your car has metric or imperial nuts, any Mini could have either. Although it may be that when new the nuts are slightly different colours, when old though that is hard to spot.
I can't think of the size of rear hub nuts but always remember they are handed.
Posted 12 March 2010 - 10:54 AM
Not necessarily - this is only true if he is asking about the front hub on a disk braked car.
As GuessWorks said - it depends if we are talking front or rear and disk or drum.
Edited by GraemeC, 12 March 2010 - 10:55 AM.
Posted 12 March 2010 - 04:23 PM
sorry guys. front on both cars.
disk on the 89.
drums on the 75.
cheers
disk on the 89.
drums on the 75.
cheers
