Changing From Drums To Disks
3 replies to this topic
#1 RWDwanted
RWDwanted
  • 95 posts
Posted 12 March 2010 - 12:41 PM
Im looking to replace the front drums with disk brakes.
Is there a list anywhere of what needs to be replaced/brought to do the conversion?
I just want to make sure im not forgetting anything.
I have done a search and couldn't find what im after, but if this has been asked before could someone point me in the right direction.
#2 Ethel
  • 26,580 posts
Posted 12 March 2010 - 12:49 PM
Minispares, and others, do conversion kits.
CV Joint
Swivel Hub
Drive Flange
Disc
Caliper
Hose (ideally)
plus assosciated fasteners.
#3 MRA
MRA
  • 7,607 posts
Posted 12 March 2010 - 02:33 PM
Hoses for discs are shorter than for drums so must be changed as well..... also while you have it all apart it is easier to do the whole job properely >_<
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 March 2010 - 03:55 PM
Easiest way is to get a complete set from a scrappy. Overhaul them and renew discs and/or caliper seals, and check the bearings and the swivel pins - then just swap over. And yes - shorter flexis are required to stop them rubbing. Obviously - you will have to go up to 12" wheels if running 10" at the moment - or - fit Fiesta Mk I calipers, and retain the 10s !
