cheers
Help!subframe Fitting
finch661
, Mar 12 2010 03:40 PM
6 replies to this topic
Posted 12 March 2010 - 03:40 PM
i amin the middle of fitting a new subframe, after having several rot problems. i have had some replacement heelboard panels welded into place after the captive nuts broke in the old ones. anyway, i have tried fitting the heelboard bolts and found that one of the captive nuts has been welded slighty off centre from the hole. the bolt wont physocally fit because of the hole is slightly covered. anyone got any ideas on what i can do?
cheers
cheers
Posted 12 March 2010 - 03:53 PM
Reweld it ? Or - drill and tap it if secure enough. Was the new heel board not fitted with the subframe as a 'jig' for location ?
Posted 13 March 2010 - 05:35 PM
i hsve managed to get the bolts to hold in the nuts, but i just cant get the subframe on. i have tried and tried, and just cant get the bolts to line up with the holes. any hints tips?
Posted 13 March 2010 - 06:32 PM
Loosely bolt the rear of the subframe then line up the front.
Posted 13 March 2010 - 06:41 PM
ah now thats a plan. i was lining up the front. has anyone found that the non-genuine frames dont fit well?
Posted 13 March 2010 - 06:42 PM
If you have a Dremel or a rotary file then carefully open up the hole in the heel board until you can get the bolt in.
Edited by sonikk4, 13 March 2010 - 06:43 PM.
Posted 13 March 2010 - 06:45 PM
aye, cheers, i bought some snading stones for the drill, may have to try and open up the holes a wee bit more
