Flywheel Housing, What Size Are The Nuts?
6 replies to this topic
#1 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 12 March 2010 - 05:03 PM
hi guys quick question, Flywheel housing, what size are the nuts on my 1993 mini
Cheers Tom.
#2 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 12 March 2010 - 05:05 PM
Sorry the 5 nuts inside.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 March 2010 - 05:27 PM
1/2" AF - any I worked on!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 12 March 2010 - 05:34 PM
1. they are bolts... ( or technically flanged bolts )
2. 1/2" AF is the size of the spanner, if they are nuts
3. which ones do you mean... the bolts holding the clutch cover to the transfer casing or the bolts holding the transfer case to the engine/gearbox
#5 jayare
jayare
  • 2,093 posts
Later ones are 7/16" AF. Still with 5/16 thread in either UNF or UNC depending on if it goes into the iron block or ali gearbox casing,
JR
#6 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 12 March 2010 - 05:42 PM
Yeah the that hold cover to block/ gearbox, there's bolts and studes which need nuts on, I have lots them you see and need to get some more from somewhere.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 12 March 2010 - 05:50 PM
use 5/16" UNF nylocs
