Model: 1000
Year: 1979
Description of problem (please be as in depth as possible): Last weekend I changed my engine and subframe, from a 998 auto, to a 1275 standard. Not thinking ahead, I didn't take pictures of how things were connected, before I started disconnecting them. I was wondering if it would be possible for someone to take the grill of their car, and take pictures of the electrical connections that are in that area, stuff like the ignition coil, and starter, and things like that, in the front of the engine.
Engine Wiring Help
willydc26
, Mar 12 2010 05:37 PM
7 replies to this topic
Posted 12 March 2010 - 05:37 PM
Posted 12 March 2010 - 08:00 PM
hi mate
cant take any pictures at the moment, however colour should be able to help you...
check all terminals and make sure they are in good condition, also check the loom for any signs of chaffing, which if left could cause a short circuit...
White/black - coil negative (also the same wire exits the loom further down to reconnect to dizzy black wire)
white - coil positive
white/brown - oil pressure switch
green/blue - water temperature sender
brown - alternator charge lead (x2)
brown/yellow - charge warning lamp lead
headlights / indicators
blue/white - flasher/mainbeam supply
blue/red - dipped beam supply
red - side lights supply
black - negative
green/red - nearside indicator switched supply
green/white - offside indicator switched supply
starter/charging
depending upon the year of the 1275 engine you may need to make some modifications to the loom.
if your old engine was the cars original engine and providing the loom is original too, the starter solenoid will be mounted on the inner offside wing. if the 1275 is a later engine the solenoid will be mounted on the top of the starter motor. unfortunatly you cannot interchange starter motors on different age engines as the teeth on the flywheel ring gear are slightly different...
let me know what age the 1275 is and if you need to modify the starting/charging section of the loom i can help.
hope this makes it easier for you.
alex
black - negative
starter/charging
alex
Posted 13 March 2010 - 04:45 PM
i am not sure as to what year the 1275 engine is, as i got it from a friend who got it from another friend who got it from somewhere. from what i can tell, it looks to be an older engine, as it looks very similar to my original engine. the colors help somewhat, but not too much, as my wires are dirty and lost their color, also i dont know minis, and dont know which posts are positive and negative on the coil and stuff. so if anyone could get a picture, it would be very helpful.
Posted 13 March 2010 - 08:59 PM
I can put up a couple of pictures but you really need to do the same?
Snap away and post them up on here from every angle and close up of certain electrical components
Posted 13 March 2010 - 10:01 PM
The coil will be marked +ve and -ve - clean it! Same for the wires - clean them with white spirit, something like that!
Posted 13 March 2010 - 10:40 PM
i will be taking pictures tomorrow i guess, if i can get some time away from the family.
Posted 14 March 2010 - 03:17 PM
so i went and worked on the mini today. i managed to get most of the wires connected, but was still unsure of somethings.
where does this wire go?
IMG00053.jpg 25.94K
9 downloads
is this purple and black wire the horn?
IMG00054.jpg 26.15K
5 downloads
i think this black cable is the heater, but how is it routed?
IMG00055.jpg 31.26K
5 downloads
and this yellow one?
IMG00056.jpg 26.64K
9 downloads
and finally, this attaches to what i assume is the starter. however, the eyelet is too small to slip over the post. is this because it came off a 998 auto, and this engine is a 1275 standard?
IMG00057.jpg 28.14K
7 downloads
IMG00053.jpg 25.94K
9 downloadsis this purple and black wire the horn?
IMG00054.jpg 26.15K
5 downloadsi think this black cable is the heater, but how is it routed?
IMG00055.jpg 31.26K
5 downloadsand this yellow one?
IMG00056.jpg 26.64K
9 downloadsand finally, this attaches to what i assume is the starter. however, the eyelet is too small to slip over the post. is this because it came off a 998 auto, and this engine is a 1275 standard?
IMG00057.jpg 28.14K
7 downloads
Posted 14 March 2010 - 03:28 PM
If you send me your email I can send some over to you.
I took lots of pictures when I dismantled mine.
1991 City E 998
If you think it may be of use, let me know
Steve
1991 City E 998
Steve
