Rear Subframe Alignment
6 replies to this topic
#1 lolipop
lolipop
  • 151 posts
Posted 12 March 2010 - 05:58 PM
1993 Rio on Hi-Lo's and smootharide cones.
Been studying the rear end wondering about strange handling issues as the car steers differently,I think understeering one way and oversteer the other.
To me it looks like the rear wheels are too far to the nearside,apparent when aligning with bodytrim and looking down the flanks towards the front wheels.
What I want to know is whether the rear subframe can be loosened and moved sideways to fix the problem? Also the nearside wheel seems to have neg camber while the offside has positive.
#2 icklemini
icklemini
  • 2,982 posts
Posted 12 March 2010 - 06:05 PM
Ah yes - sounds like a classic case of rear wheel toe sticking out on one side.. and in on the other...
You can try to align the subframe with the body.. though this is rarely successful. and wont help if the wheels are pointing in the wrong direction.
Camber and tracking brackets (once setup) are a common way of adjusting the individual toe and camber of the rear wheels.
#3 lolipop
lolipop
  • 151 posts
Posted 12 March 2010 - 06:11 PM
Thanks,is there much sideways movement possible with the subframe loose? Or are the camber/tracking brackets the way to go.
#4 jayare
jayare
  • 2,093 posts
Posted 12 March 2010 - 10:00 PM
There is almost zero sideways movement in the subframe even when loosened,
JR
#5 lolipop
lolipop
  • 151 posts
Posted 27 March 2010 - 09:57 PM
Right,been examining this a bit more and got a couple of shims to try.Am I right in thinking that shims will only produce more toe out,as I cant see any way that fitting them would give more toe in.
#6 DoubleHB176
DoubleHB176
  • 36 posts
Posted 27 March 2010 - 11:12 PM
I fully recommend a professional set up on jigs and such.
Many autobody repair type places have facilities for this, with laser measuring tools and equipment.
I had mine done on this as I had some odd handling traits, it made such a difference !
Many places are also willing to cut deals, it worked out much cheaper than I had expected.
#7 icklemini
icklemini
  • 2,982 posts
Posted 27 March 2010 - 11:13 PM
correct
camber/toe brackets are an option...though depending on the quality of the subframe these still may not offer enough adjustment...
