Replacement Valve Guides Very Snug On Valves!
Posted 12 March 2010 - 11:46 PM
Posted 12 March 2010 - 11:59 PM
find a local company that can correct them using the right tools for the job....
A reamer NEEDS at least 0.003" to work as the guides where machined as a perfect fit to the valves before fitting in the head, you will only need to take out about 0.0003" a reamer will simply "bounce" around in the hole and create more damage
The better the job the longer it will last
Posted 13 March 2010 - 12:11 AM
Not reamed..... definately NOT reamed, there are a couple of ways of dealing with this type of issue, firstly do not force the valves in to the guides again
The better the job the longer it will lastgiving you more miles per £ and less hassle
Coolio, anybody know anybody good in the Nottingham area?
