Year: 1993
Had a problem with my headlights (sealed beams) in which one headlight worked and operated normally, but the other one only the sidelight worked. The bulb was fine, but to be 100% sure I bought a new set of Wipac Quadoptic Halogen headlights (I was going to buy these at some point anyway).
Installed them about an hour ago but the same sort of thing seems to be happening
When the sidelight is turned on, there is no problem - the sidelight lights up.
When the dipped beam is turned on, the sidelight dims and the headlight comes on but dimly also.
When the main beam is turned on, the sidelight and headlight dim even more
I know its a wiring issue, but I dont really know where to start! Have tried changing the big pink relay (dim dip relay?), but the same thing happened.
I'm supposed to be heading out into the countryside in an hour or so, so if anyone could help it would be most appreciated.
Here are some pictures (click to make bigger)
Sidelights:
Headlights
Main Beam
Any non-standard parts that might be involved with the problem?
Wipac Quadoptic Halogen Headlights
