first we need to gain access to the area we are working on
ramps, axle stands ETC
remove trim, carpet ETC
and don't forget to disconnect the battery if your welding
your going to need your protective clothing, goggles face mask ETC
next step is with grinder in hand cut away rusty area until you have clean bright steel
after having your wheatabix use some card from the box and make a template for whats needed to fill the hole, then cut some steel to match
next its crack the welder out and weld patch on, grind off welds once done to neaten the job up
once done fill any imperfections and paint
job done total time spent on job 2 hours
