Windows Photo Viewer Troubles.
14 replies to this topic
#1 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 14 March 2010 - 12:45 AM
Hello all,
PC boffins are needed here. This is starting to drive me mad.
When i open certain pictures, they come up as a thin line. The wierd thing is, it doesnt matter about format, size, or where i've saved them from. And its not a certain album, its just random pictures. It isnt the way they've saved either, because if i open them with quicktime pictureviewer, they show up fine, as they do in paint, i just dont understand it.
Heres a picture to show you what i mean.
#2 captainjack15
captainjack15
  • 3,925 posts
Posted 14 March 2010 - 02:33 PM
I can see your problem......
You've got Windows 7 :)
#3 Eatsleepdrink
Eatsleepdrink
  • 332 posts
Posted 14 March 2010 - 02:47 PM
Well I had a look around on google as a few people are having this problem.. most are just using a different program such as irfranview.
Im on win 7 so you could send one of the problem pictures to me and see if I get the same problem, which would determine whethers its yours windows 7 having some problem system files or if its the actual photoviewer.
#4 Mini-Mad-Craig
Posted 14 March 2010 - 03:03 PM
Open them with quicktime then? just set the default program for jpegs, Bitmaps etc to quicktime viewer?
#5 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 14 March 2010 - 03:52 PM
Windows update provides a fix for this problem.
Run all the updates from www.windowsupdate.com - i cant remember from memory if its classed as an important or optional upgrade.
The other thing is, did you recently install any graphics editing software, i found the problem happened to me after I installed corel.
#6 Down&Out
Down&Out
  • 4,853 posts
Posted 14 March 2010 - 06:57 PM
You cant flick between photos using the arrow keys with quicktime, otherwise i would :)
I didnt recently install graphics editing software, so it wont be that, ill try that site :dontgetit:
#7 Calman
Calman
  • 1,674 posts
Posted 14 March 2010 - 07:12 PM
Mine done this last night (Vista) All i done was open the screwed image in paint or w/e and then save it as the original save name so that it overwrites. Then go to view it again and Bobs your aunty all better. :)
#8 Down&Out
Down&Out
  • 4,853 posts
Posted 16 March 2010 - 11:44 PM
Just to add, updates didnt work.
#9 maryquant
maryquant
  • 932 posts
Posted 17 March 2010 - 02:22 AM
Just found this.... it makes sense, but I take no liability etc etc.
basically it should reset WPV again for you
Press the start button in the bottom left corner of your screen.
A start menu should pop up.
Click on "Run" on that start menu.
When the little box pops up, type this in the white part of the box:
regsvr32 /u %windir%\system32\shimgvw.dll
A process should start.
When that process has completed,
Click on Start, then Run... and type in:
regsvr32 /i %windir%\system32\shimgvw.dll
This should reinstall the Windows Fax and Picture Viewer on your computer.
(You may have to reboot after this for it to work.)
#10 Down&Out
Down&Out
  • 4,853 posts
Posted 17 March 2010 - 04:51 PM
It just came up with an error message saying this:
#11 minicooperaniversary
  • 143 posts
  • Local Club: King's Lynn Mini Owners Club
Posted 14 September 2010 - 03:30 PM
If you never sorted it, here's a solution: Download Picasa 3 from Google - It acts as a nice photo sorter and includes a viewer - It looks way nicer and acts smoother than the vista/7 one as well (Well, in my opinion anyway)(all you have to do is use the arrow keys to zoom + move back and forth effortlessly through your photos). Only downside is that you can only open one pic at once in the viewer. (and yes, I do realise the standard one can also act as a photo sorter)
Eg:
You've got Windows 7 :D :)
Windows 7's great :)
Edited by minicooperaniversary, 14 September 2010 - 03:34 PM.
#12 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 14 September 2010 - 04:59 PM
I'd much rather live with one superficial problem like this than make an attempt to live with Vista!
I also have this issue, generally with images that came off my old phone camera.
#13 minicooperaniversary
  • 143 posts
Posted 14 September 2010 - 08:16 PM
Vista isn't that bad- and yeah, I've never had that problem with Picasa, even on photos that Windows Photo Gallery 'mucks up'.
(And yes - the example photo is one I took :-)
#14 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 14 September 2010 - 08:37 PM
(And yes - the example photo is one I took :sneaky:)
It's bloomin' awful!
Nothing is laid out in a logical manner so finding something is usually a case of use the search or spend your entire life finding that setting you want.
Not to mention every time you want to change a setting Vista thinks is even remotely important the screen blacks out and asks you if you're sure about 500 times. It's supposed to be an operating system not a nanny.
Hate it :-.
7 is lovely however, ;). Even more so when you don't have to pay for it ;D.
#15 The Reverand
The Reverand
  • 241 posts
Posted 14 September 2010 - 10:17 PM
I've got Windows 7, and making things as awkward as possible was my idea :-
