Cam Timing!
13 replies to this topic
#1 Mei
Mei
  • 74 posts
Posted 14 March 2010 - 07:20 AM
I've been trying to time my camshaft in and have become a little confused!!
im trying to figure out which way to go for allowing the chain stretch...so for example
If i've been told 108 is perfect...then to take into account of stretch (im going to do 1 degree out) should i be looking for:
109 or 107
If anyone has any answers for this, it would help me out alot!!
Mei
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 March 2010 - 07:46 AM
The chain stretches more than 1 degree, time it at 106.
What cam is it?
Edited by Paul Wiginton, 14 March 2010 - 07:47 AM.
#3 Mei
Mei
  • 74 posts
Posted 14 March 2010 - 07:52 AM
Thnkyou very much for your reply!
SW5-07 is the cam!
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 March 2010 - 07:54 AM
No problem, it wasnt Swifty that told you 1 degree for stretch was it?
#5 Mei
Mei
  • 74 posts
The manual says time it anywhere between 106 to 108
#6 Mei
Mei
  • 74 posts
Posted 14 March 2010 - 07:55 AM
No swifty didn't tell me, it was a word of mouth job!
#7 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 March 2010 - 07:57 AM
Good, Swifty would confirm what I said.
I check my timing after every event and the chain always stretches 1.5 degrees after only about 10 miles from new
#8 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 14 March 2010 - 07:59 AM
Hahaha, oddly enough hopefully going to be timing in my cam today! its an SW-10 so runs on the same timing principals of the SW5..
the sheet of paper says 106 to 108, so call that 107..
then take in the 2 degrees for stretch
so im going to be timing it at 105 to make sure the timing will be dead on, after running in time!
hope that helps!
#9 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 March 2010 - 08:03 AM
Its best to recheck the timing after running in - before going to the rolling road. Its very easy to do in the car
#10 liirge
liirge
  • 4,097 posts
Posted 14 March 2010 - 08:05 AM
Yer that's probably a wise move there paul! its even easier if you have a vernier set, the adjustment can be made so quickly with little fuss!
Edited by liirge, 14 March 2010 - 08:21 AM.
#11 liirge
liirge
  • 4,097 posts
Posted 14 March 2010 - 01:37 PM
Just done mine, ended up timing her in at 106 technically 105.75, so that should be fine!
#12 Mei
Mei
  • 74 posts
Posted 14 March 2010 - 02:22 PM
Thankyou all so much for the help! timed it in at 106.5 in the end!! yay
there's one more thing that I need help with guys...
Which way does the oil thrower thingy go round?
Mei!
#13 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 March 2010 - 02:47 PM
I think if its backwards itll drag on the chain, it should only fit one way comfortably so the outer edge is further outwards - if that makes sense
#14 Cooperman
  • 23,513 posts
Posted 14 March 2010 - 05:16 PM
Paul, I think it goes with the step on the face inwards and it just clears the chain. That's how I always fit mine.
As for cam timing/chain stretch, you are absolutely correct about initial chain stretch. The chain stretches a lot, approx 1 deg to 1.5 deg, during the first few miles, say 10 miles to 100 miles, then the stretch settles down and only stretches that much again in the next 10,000 miles or so. I always set to 2 deg to 3 deg advanced to allow for this.
Yes, as the measurement is ATDC, you subtract the allowance from the cam manufacturer's nominal setting to get your best initial setting.
Edited by Cooperman, 14 March 2010 - 05:16 PM.
