Air Bubbles On Dipstick
4 replies to this topic
#1 Pete867
Pete867
  • 14 posts
Posted 01 September 2010 - 10:51 AM
Hello
I've just started up my 998 clubman (with 12G295 head, MG Metro cam, +40 flat top pistons, new bearings) and ran it for about 5 minutes. When I turned it off I checked the oil and noticed some tiny air bubbles on the dipstick. Is this normal or should I be concerned? I haven't overfilled/underfilled with oil.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 September 2010 - 03:25 PM
were the bubbles fuel from a leaky fuel pump ?
#3 Pete867
Pete867
  • 14 posts
Posted 01 September 2010 - 04:50 PM
we the bubbles fuel from a leaky fuel pump ?
Can the fuel get into the oil? I will check it out..
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 01 September 2010 - 05:13 PM
Well think about it....
While the engine is running, even when stationary the gearbox is turning at what, 1000 rpm ....
Would you be surprised that the oil is just not sitting in the bottom of the sump, it's being thrown around by both the gears and sloshed back into the box by the oil pump at something like 6 gallons a minute..
Unless you've left the engine settle for a while there's every chance there's going to be bubbles in it
And there's little point in checking the oil just after it's stopped running as there's still quite a lot around the walls of the crankcase which needs time to drain back to the sump.
Edited by Guess-Works.com, 01 September 2010 - 05:14 PM.
#5 Pete867
Pete867
  • 14 posts
Posted 01 September 2010 - 06:06 PM
That does make sense, I'm a novice (this is my first build) so I'm terrified when something looks/smells/sounds odd! :)
I checked the oil and couldn't smell any petrol in it, which is a relief
Thanks for the help
