Smoke Coming Out Of Crank Breathers
Posted 01 September 2010 - 02:01 PM
Posted 01 September 2010 - 04:59 PM
Posted 01 September 2010 - 05:49 PM
Posted 01 September 2010 - 07:09 PM
On the 18/8/10 it was 4=10.5, 3 =11.5, 2=11.5, 1=10.5 .To me that's not too bad, is it?
Posted 01 September 2010 - 08:28 PM
It doesn;t really matter too much what the actual figure the test shows is, more that they're all pretty even with each other.
Posted 02 September 2010 - 10:46 AM
with about 10cc of oil down the bore 4=14,3=14,2=15.5,1=15.5. Is that good, bad or ugly?
Posted 02 September 2010 - 10:48 AM
EDIT: You can't be sure until you pull the head off though.
Edited by AndrewJ530, 02 September 2010 - 10:49 AM.
Posted 02 September 2010 - 11:01 AM
plus, 160psi compression on each isn't bad at all.
If it's a new engine on the other hand,then something isn't quite right.
Posted 02 September 2010 - 02:47 PM
just start planning/saving for a rebuild at some point in the future.
Posted 02 September 2010 - 03:09 PM
Edited by HUBBA.HUBBA, 02 September 2010 - 03:32 PM.
Posted 02 September 2010 - 05:11 PM
Posted 02 September 2010 - 06:12 PM
Posted 02 September 2010 - 09:47 PM
Posted 02 September 2010 - 10:04 PM
Posted 03 September 2010 - 09:24 AM
bmcecosse - You are putting my mind at rest. Strangly, to be fair I'm not so worried about the effects of the fumes, more the sudden cause of them. I want to get things all tickety boo before I supercharge the beast. There are other implications as well as I may have to choose between deeeeeep dished pistons or getting the head chamber machined to reduce the compression. So if it is the rings on the way out then I am thinking change to the deep pistons.
Any more comments much appreciated
