Clutch Problem :(
1 reply to this topic
#1 mini e tom
mini e tom
  • 39 posts
Posted 02 September 2010 - 09:48 PM
right guys iv had my 85 city e sat on my drive for about 3 months, i spent all day trying to get it running and went to drive it into my garrge and my clutch is now stuck to the floor :)
what do i do to free it ?
please help
trying to get my mini reddy for uni
thanks tom
#2 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 02 September 2010 - 10:22 PM
Are you saying that the pedal has gone all the way down to the floor and not come back up again? The pedal should be pushed back up automatically by the spring in the pedal box. Check to see if the spring has broken or come off the pedal.
If you mean by pressing the clutch pedal all the way to the floor and the clutch is not releasing then try checking the fluid level in the clutch master cylinder and check for leaks between the master. Check to see if when pushing the clutch pedal that the slave cylinder is actually moving.
If there is no or little hydraulic fluid in the clutch system you may need to bleed it to get rid of the air.
