My Battery Keeps Going Flat Mmmm :|
4 replies to this topic
#1 luiji89
luiji89
  • 1,039 posts
Posted 02 September 2010 - 10:14 PM
hey all, i have a 1989 minii city e
it has recently had spotlights and radio fitted etc, since it has been back on the road the battery keeps going flat!
i have no clue whats the problem, sooo please could you help :)
thanks toby
#2 joewb
joewb
  • 436 posts
Posted 02 September 2010 - 10:20 PM
first guess would be the radio left on a constant live, was it hardwired into the car? i had my one fitted (changing from a standard cassette player, so needed to be hard-wired) and was put on a constant live so as to flash so it looked like it was in the alarm system. may be a bad case of that.
#3 luiji89
luiji89
  • 1,039 posts
Posted 02 September 2010 - 10:22 PM
it only works when the key is turned at least once?
#4 Sagey
Sagey
  • 487 posts
  • Local Club: The mini forum
Posted 03 September 2010 - 07:02 AM
go halfruads and get battery tested :) then work from there your battery might be dead, and will keep dyin :)
#5 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 03 September 2010 - 10:25 AM
First check the ignition warning light on the dash (red light on bottom right of fuel/temp dial). It should illuminate when the ignition is switched on and go out immediately when the engine starts. If this doesn't happen then it points towards there being a charging problem, if it lights up and then goes out as described then either your battery is the problem or you are somehow draining it.
