Any body know what pressure I should set the filterkings pressure regulater to, it's currently at 4 psi (i've got a range of 1- 7psi to play with).
Out of interest what happens if the pressure is too high?
Fuel Pressure From Facet Pump
HUBBA.HUBBA
, Sep 03 2010 09:34 AM
7 replies to this topic
Posted 03 September 2010 - 09:34 AM
Posted 03 September 2010 - 10:20 AM
If its too high your float in the carb will overflow out of the overflow pipe on the side of the carb.
I think it needs to be set between 3-3.5psi. I just read it in another thread that thats what an SU carb is designed for.
Edited by mike., 03 September 2010 - 10:20 AM.
Posted 03 September 2010 - 06:00 PM
Thanks Mike. I saw that thread, but wasn't sure if it applied to all SU's. So 4 psi should on the money with tuned engine, I would think.
Posted 03 September 2010 - 11:39 PM
yeah should be fine with 4psi, i wouldn't go any higher personally.
Posted 24 May 2011 - 07:24 PM
I'm also really interested in this..
are you sure a hif44 carb can go with 3-4 psi?
This facet is ok for hif44+1380 engine?
http://www.minisport..._FAC40105K.html
Posted 24 May 2011 - 07:28 PM
Had mine on 2.5 psi at first acted like a limiter at 6500rpm 3 psi was just fine for me - hif44 stage 3 head 1310cc
Posted 24 May 2011 - 07:31 PM
I've been running at 3.5 ever since and it's been fine.
I run 3.5 on my 115 bhp 1310 cc 'S' with twin H4 carbs.
