Mk4 Mini City
702 replies to this topic
#166 Lund
Lund
  • 1,864 posts
Posted 28 April 2006 - 09:53 PM
similar damage to my mini, heritage panels and re primer and labour plus the vat man
thats new rear and whole quater
£2000.00
insurance giving me a check to do the work though so its all ok
Gaz
Oh right, I thought i was the only one :D !!!
#167 mini-gti
mini-gti
  • 614 posts
Posted 28 April 2006 - 09:56 PM
£2000.00
Gaz
nah mum decieded to start her car in reverse and hit my mini :-
#168 Lund
Lund
  • 1,864 posts
Posted 28 April 2006 - 10:05 PM
£2000.00
Gaz
Oh right, I thought i was the only one :- !!!
nah mum decieded to start her car in reverse and hit my mini ;)
:D
If I buy the rear panel and valance and then give them to him to weld on and pull out the crease. I could do the rest myself, I.e painting and fitting the rest of the boot etc... That would bring the cost down a little :(
#169 mini-gti
mini-gti
  • 614 posts
Posted 28 April 2006 - 10:16 PM
the two panels for minie come to around the 600 quid mark, but they are full panels, you could probably get away with half hight panels
gaz
#170 Lund
Lund
  • 1,864 posts
Posted 28 April 2006 - 10:19 PM
gaz
I thought the same, but it's best that i get the FULL rear back panel asembley, will see what i can pick up at Himley Hall :- I think its about £200 for a genuine full rear panel
I have the boot all ready and prepared
:D Thanks for your Input
#171 Lund
Lund
  • 1,864 posts
Posted 29 April 2006 - 01:05 PM
:D
Bought a new set of points, hopefully she should respond better when turning her over :-
Cost a Fiver! For a set of Points! :(
Tom
#172 Lund
Lund
  • 1,864 posts
Posted 29 April 2006 - 09:28 PM
:D
Cost a Fiver! For a set of Points! ;)
Tom
The points are the wrong ones!
#173 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 29 April 2006 - 09:51 PM
Which ones are the wrong ones?
and which do you need?
(which dizzy do you have?)
#174 Lund
Lund
  • 1,864 posts
Posted 01 May 2006 - 11:50 AM
I'm not sure what dissy I have, I think its standard 850, 1979 I think... :D
Ones off the Mini:
The new set (wrong):
Does that help?
#175 ed4ran
ed4ran
  • 2,849 posts
Posted 01 May 2006 - 01:20 PM
Ill have to check, but i bought a new set and never installed them before i removed the dizzy.
If i can find them, and if they are the right ones then you can have them.
Have you tried giving the contacts a bit of a sand though?
#176 Lund
Lund
  • 1,864 posts
Posted 01 May 2006 - 05:29 PM
Cheers mate, thats a very thoughful kind offer, I'll take you up on that! :D I'm hopeless at getting parts that are actually the right ones! :angel:
:w00t:
#177 Lund
Lund
  • 1,864 posts
Posted 08 May 2006 - 08:00 PM
:thumbsup:
#178 Lund
Lund
  • 1,864 posts
Posted 31 May 2006 - 04:34 PM
The last time you will see my Mini like this:
Hopefully! :D
#179 Lund
Lund
  • 1,864 posts
Posted 31 May 2006 - 05:35 PM
It's got a mind of its own right now! :D It used to spark on the old weak set of points, but now Ive replaced the points its not sparkin at all, used the feeler guages to set the points at 35. Recommended by Haynes manual, but its decided it doesnt like it at all, the engine is sound just not sparkin up, new coil/condensor maybe? Im going to have a dig at it tonight to try start it up. :-
Had a guy from the bodyshop to come have a look at the Mini for me today, he said that it looks worse on the pictures and could be done, one problem is that it needs to go on the jig to be pulled out, but where can the clamps of the jig fix to? Needs to be a flat very strong and supportive place, any ideas? Thought about on the side of the sills, in the hole that is about 1 1/2 inches deep, maybe strut a pole into that and fix it, also wrap a truck strap harness thingy :D around the front subframe to keep it down and in place (as crude as it sounds!) as the Mini is going to be under alot of pressure on the jig, as the Mini almost becomes part of the jig. Any suggestions as to where to fix the clamps of the jig to the Mini? It has to be a strong supported place to under go quite a bit of pressure, with out damaging the Mini.
:D
#180 RacingGreen
RacingGreen
  • 2,111 posts
Posted 31 May 2006 - 08:05 PM
Shouldn't the people that own the jig know how to do it?
