Compression Ratios And General Turbo Newb Questions
15 replies to this topic
#1 carts60
carts60
  • 1,007 posts
Posted 31 January 2011 - 05:25 PM
Hi all,
Im very interested in turbo'ing my mini in the summer when i finish uni, as iv got some funds stashed away for a rainy day. I was initially just going to rebore & rebuild the engine, but if you're going to do something, you've got to do it right first time round - so i thought id go gung ho and go down the turbo route.
Basically, the spec im looking at is (questions included in brackets)
Target - 120/130bhp
T2 turbo
Overbored block to 1293.
Rehoned & refaced
ARP bolts (does my block have 9 or 11? & which is best)
Centre main strap - 2 bolt
Standard crank (unless recommended mods?)
Replace crank bearings
Replace cam bearings
New pistons (Need suggestions!)
Standard rods (unless others recommended?)
Omega piston rings
ARP rod bolts
New cam (recommendations?)
Vernier duplex timing chain
New cam followers
(Are roller-rockers necessary?)
Machine my current head (is that possible for turbo use & what mods?)
High capacity oil pump
Ally 2 core rad
Small intercooler
Recondition my current gearbox (will this cope with a turbo?)
X pin diff
(Should i change the final drive?)
Center oil pickup
Lightened flywheel
Lightened clucth
Grey pre-verto clutch
So thats it! I think?
I really don't want to have to put in straight cut gears unless absolutely necessary because i dont think i could live without decent music in the car and from what i can tell, SC gears drown out everything (although i like the sound itself its not one to listen to for hours on end)
Is there anything on the list iv missed or that is actually on it but isnt necessary (iv got a budget in mind that i dont really want to exceed, so anything thats really not needed, il try to avoid). Obviously i don't want to try and cut corners or skimp on quality parts either though.
Oh, i also need some advice on suitable compression ratios and how to achieve such a ratio. I'v been advised a ratio of 8.0:1 is good?
Edited by carts60, 31 January 2011 - 05:28 PM.
#2 eden7842
eden7842
  • 907 posts
Posted 31 January 2011 - 06:35 PM
ayup mate
i think your going a little over spec when ur only looking for 120 - 130 bhp. a decent 1275 metro turbo lump will pull that easy.
did you ever see my turbo? ud be welcome to come and have a look if you want that way you can see whats involved rarther than
looking at pictures.
eden
#3 Liam Mini 35
Liam Mini 35
  • 412 posts
  • Local Club: sheffield mini club
Posted 31 January 2011 - 07:36 PM
as above spec looks very high for that amount of power. Why dont you look at a supercharger? A lot easier to fit and you could get that power easily. From a 1293/1310
#4 Liam Mini 35
Liam Mini 35
  • 412 posts
Posted 31 January 2011 - 07:38 PM
also have a look at www.turbo-minis.com, lots of useful info on there re engine specs, comp ratios etc.
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 31 January 2011 - 08:14 PM
Have you read this ? 130hp basic build
Have you read this ? Compression ratio guide
Phil.
#6 carts60
carts60
  • 1,007 posts
Posted 31 January 2011 - 11:25 PM
Eden mate - i might have to take you up on that offer. No, i never saw your turbo. You definitely mentioned it when i came to the meet, but you still had twin carbs and only 2 wheel arches lol Il PM you some time soon so we can arrange a suitable time and place. That would be a great help!
Yeah, im a new member on turbo-minis - got a grand total of 8 posts odd!! They're great there, although i feel like a plonker asking such basic questions to guys who've clearly been doing this for years, so i thought id post this here first!
Phil, you're a life-saver. Iv been through you're website a few times but haven't seen that 130hp build before!
No doubt il be posting back here soonish
#7 carts60
carts60
  • 1,007 posts
Posted 31 January 2011 - 11:29 PM
Back already!
I know the mini gearbox is the weak part of the whole engine assembly, but are straight cut gears necessary. Phills guide says they're recommended, but if i can do without, it would be good. Im a music man, and the whine the box makes, although its a good sound to hear would annoy me so much over the top of my music!
I would consider them however if it was realistic to try and block out most of the sound with dynamat (or equivalent) or some other sound deadening tech.
#8 jamie@thefatgarage
jamie@thefatgarage
  • 120 posts
Posted 31 January 2011 - 11:33 PM
Hmm... 7.8:1
Lots of boost and a massive intercooler.
New trousers recommended!
#9 carts60
carts60
  • 1,007 posts
Posted 31 January 2011 - 11:47 PM
OK here goes - my new & improved look spec. Have a gander if you please:
Modified head - 29mm exhaust, 36 inlet + ported & polished
1293 block rehoned & refaced
ARP head studs & drill block & head to fit 11
Metro turbo pistons
ARP rod bolts
Kent 266 cam
Vernier Duplex Timing chain
Grey diaphragm & AP rally backplate
Twin pin diff
Intercooler
High grade cam followers
Quality main & big end shells
Other new odds and sods that crop up along the way.
Compression ratio of 8.6:1.
Sound better? It sounds better to my pocket at least!
#10 eden7842
eden7842
  • 907 posts
Posted 01 February 2011 - 12:45 PM
yeah drop me a pm. Il be happy to talk you through it. Gimmi a month and my 1293 should be in got a tempory 998 turbo atm. Also iv got a spare cross pin diff which il be sellin soon
#11 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 01 February 2011 - 09:29 PM
Spec looks good but one problem metro turbo postons will be 1275 so your gonna need some new psitons. In this area I would get the best you can afford.
Edited by Sleepy Stu, 01 February 2011 - 09:30 PM.
#12 carts60
carts60
  • 1,007 posts
Posted 01 February 2011 - 10:36 PM
Do you have any pistons in mind in that case?
#13 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 01 February 2011 - 10:52 PM
The cast Omegas are excellent.
#14 carts60
carts60
  • 1,007 posts
Posted 01 February 2011 - 11:02 PM
These?
Here
#15 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 02 February 2011 - 07:48 AM
0.020" x 10cc central dish for forced induction use, here
Edited by Turbo Phil, 02 February 2011 - 07:49 AM.
