Still got a few bits left........................
1 x Rear Screen (MPI, Tinted but a couple of the heater elements need repair) - USED - £ FREE for collection
1 x Intake Air Control Valve (IACV) - USED - £15 -
SOLD1 x Throttle Position (TP) Sensor - USED - £10
1 x Throttle Position (TP) Sensor - NEW - £20
1 x Manifold Absolute Pressure (MAP) Sensor - USED - £15 -
SOLD1 x Intake Air Temperature (IAT) Sensor - USED - £10 -
SOLD1 x Camshaft Position (CMP) Sensor - USED - £20 -
SOLD1 x Heated Oxygen (H2OS) Sensor - USED - £20
SOLD1 x Engine Coolant Temperature (ECT) Sensor - USED - £5 -
SOLD1 x Standard (Plastic) 48mm Throttle Body - USED (with NEW TP Sensor) - £25 -
SOLD1 x MPi Expansion Tank with Cap - USED - £5
1 x Original Cooper Sport Chrome Badge - USED - £5
1 x Pair Metro Turbo Vented Discs - USED (light skim) - £10
1 x FSE Power Boost Valve Pressure Gauge - NEW - £5 (gauge will screw straight into PBV)
1 x Pair NEW Rear Wheel Bearings (Taper Roller) - £20 the pair - GHK1805
1 x Standard Rover Top and Bottom Hose Set for MPi Mini - USED £20
1 x Pair Long Type Track Rod Ends (C-AJJ1572) - £15
1 x 4ft steel braided oil pressure hose (for mechanical oil pressure gauge) - C-AHT9 - NEW - £10
1 x MPi LCB, Y Piece, Link Pipe & De-Cat Pipe with H2OS sensor tapping in the top Y piece - 1.3/4" Bore - A bit rusty but appears to be in useable condition - c/w 2 x NEW Catalyst Flange Gaskets, NEW Manifold Gasket and Brass Nut Set = £30 -
SOLDOpen to offers
5 mins from M1 Junction 20 (Lutterworth, South Leicestershire.)
Nick
Edited by nicksuth, 08 May 2011 - 06:28 PM.
