1980 Clubman Estate..another Sandglow
68 replies to this topic
#1 mini-adam
mini-adam
  • 79 posts
Posted 31 August 2011 - 10:09 PM
Couldn't resist being tempted by this as it was only two doors away from where I live and was owned by an old lady from nearby.
Back in 1991 the car was given to a local mini expert to get a few rusty bits sorted out. He replaced sills, cut out and repaired a few holes in the floor and a wing replaced. Then he left it up to a bodyshop and mechanic fella a few hundred yards away to get repainted, a replacement goldseal engine fitted. When this was happening the elderly lady owner passed away. The fella waited till all the family had the will sorted and done a deal with them to pay for the work done. He put a sheet over it and pushed into the back of the workshop where it sat for the next 18 + years.
I bought it last year but have only now got around to the serious business of its restoration
just as when we got it home
The sheet was obviously not dust proof as the roof has overspray
after a bit of clearing out of the interior
parked up beside our other sandglow mini.. 1977 1000
Edited by mini-adam, 10 November 2012 - 11:14 AM.
#2 mini-adam
mini-adam
  • 79 posts
Posted 31 August 2011 - 10:29 PM
Got the paintwork washed and compounded with various grades and wasn't coming up too bad
The bonnet had black paint specks all over it..
#3 analogue_radio
analogue_radio
  • 4,897 posts
Posted 01 September 2011 - 06:31 AM
:o
Lovely!
#4 bcjames
bcjames
  • 2,741 posts
Posted 01 September 2011 - 07:11 AM
The transformation on the paint is incredible, looks amazing. The 18 years under a sheet have been very kind to it, is there much to do? It all looks so solid!
#5 mini-adam
mini-adam
  • 79 posts
Posted 01 September 2011 - 09:56 AM
The underside of the floor had surface rust, it was never treated other than paint, a few rusty bits showing up on edges of the window surrounds. Going to respray it as touch-up will be so noticable.
Besides one sandglow mini is enough
#6 Montytom
Montytom
  • 53 posts
Posted 02 September 2011 - 11:26 PM
This brings back memories my first ever mini was a clubman estate. Never really liked it at the time but now I absolutely love the shape and would so like another one. Please keep us updated regards Thomas
#7 mini-adam
mini-adam
  • 79 posts
Posted 04 September 2011 - 08:36 PM
Thanks for the encouragement.
Have tackled the engine bay, underside and the wheel arches.
floor came up very well, mostly surface rust, cills fitted 18yrs earlier were like new
Next tackled the front arches, cleaned off underseal and etch primed..
in process of primer
applied some seam sealer over joints
stonechip layer before primer
now for the underside..
took off the jacking points to reveal a hole or two
plated the hole that I cut out and plated over that as well, so it will be stronger
#8 Zeemax Adventure
Zeemax Adventure
  • 301 posts
Posted 05 September 2011 - 10:14 AM
wow what a find. To still be in that condition after all these years. Goes without saying you dont know whats hiding around the corner :)
#9 mini-adam
mini-adam
  • 79 posts
Posted 14 September 2011 - 10:26 PM
few updates to the progress, removed the fuel tank and cleaned off underseal to the wheel arches and boot underside... what a messy job that is, although there wasn't much underseal used on the floor.. ie none
top of the tank had a thick layer of grease which had protected it well
cleaned up the tank and treated the surface with Krust prior to a coat of etch
removed the underseal and found a few holes
boot area cleaned and etch primed and joints seam sealed
#10 mini-adam
mini-adam
  • 79 posts
Posted 03 November 2011 - 10:55 PM
tackled the dash and decided to remove the padded dash rails. Want to fit a centre speedo and new flick switches
went from this..
to this..
and finally..
#11 mini-adam
mini-adam
  • 79 posts
Posted 14 July 2012 - 04:37 PM
moved on with the outside front and decided to de-bumper and change the look of the indicators. Bit of fettling with the holes and flushing out here and there to git rid of blemishes
#12 mini-adam
mini-adam
  • 79 posts
Posted 04 November 2012 - 04:53 PM
some updates on this project...
got a bit distracted and put on a supalight 13x7 I had. Dunno might be a bit wide. Would have to cut the front wing for these.
got back into repair mode again and went to the rear panel under the bumper and found this, new piece ordered.
few wee ripples in the metalwork under the filler cap, although sound just needed a skim of isopon
went to the door skin and surprised that when finished who uneven the original finish was
tackled the inside surfaces and cleaned all down prepped and 2k primed. I also removed the rear pockets
the panels at the rear floor were removed and painted including the underside in a white 2pk. Want to refit these before applying top finish coat
Back to where the rear pockets were I found a rusted area and ended up with this hole cut out, before getting good metal to weld to
the inside got another primer coat and brush painted with a 2pk white left over from another job
Spotted these for sale locally and came out of an Evo 1, comfy as anything and plenty of colours to choose from in the pattern
Edited by mini-adam, 06 November 2012 - 12:46 PM.
#13 stealth05
stealth05
  • 626 posts
Posted 04 November 2012 - 05:00 PM
awesome work mate .
#14 MentalMini
MentalMini
  • 17 posts
Posted 04 November 2012 - 08:31 PM
great find and good work so far i have a 79 clubby estate......do you know where to find the paint code on an estate ?
#15 mini-adam
mini-adam
  • 79 posts
Posted 04 November 2012 - 10:12 PM
Sorry I wouldnt know where the code is.. maybe the chassis plate. or post a pic on a thread and someone will know the colour
