Fuel Tank Sender Unit - 1275Cc
Posted 08 October 2011 - 10:42 PM
Would anyone know what the ohms resistance readings are on the fuel sender unit? I have tried in the Haynes manual but nothing.
I am fitting one of these ETB digidash units and it has the faciltiy to read the fuel tank level. I would think it would be something like 50 ohms full 230 ohms empty???
I guessing really have no clue!
Pistonbroke
Posted 09 October 2011 - 12:06 AM
Empty = 270 Ohms.
The actual range will vary from sending unit to sending unit. A more reasonable expectation would be a range from 240 Ohms = empty to 33 Ohms = full... which is an industry standard.
The only way to tell for sure is to run your tank to what you want to read as empty, I leave 2 litres at this point, so I know I will always have enough, and shove a meter on it to check resistance, then fill her to the top and check again!
Posted 09 October 2011 - 12:58 PM
Full = 10 Ohms
Empty = 270 Ohms.
Good News,
I think I can get that to work with the ETb thanks very much for the information top man!
Pistonbroke
Posted 09 October 2011 - 01:44 PM
