Building A Wiring Loom
11 replies to this topic
#1 shaddy
shaddy
  • 159 posts
Posted 30 November 2011 - 03:49 PM
Right I am planning on making my own wiring loom for the car it only needs to be basic as it is for a lightweight track day car. which will be running lights, horn wipers etc and a canems ecu
Can anybody recommend any useful books on building a new complete wiring loom or has anybody got any tip on this subject.
any help will be Appreciated
cheers Andrew
#2 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 30 November 2011 - 03:54 PM
could younot just modify an original loom and possibly retain the original colour code scheme?? it just comes accross as the handier option to me!
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 November 2011 - 04:13 PM
You don't need a book - it's so simple!
#4 shaddy
shaddy
  • 159 posts
Posted 30 November 2011 - 04:17 PM
i could do but i want to sart from scratch and try and get rid of all those problems you get with a minis electrics. i rally don't want to start cutting and piecing looms together, and adding connections all over the place. i also forgot to add my speedo and gauges are not standard so big chucks of the loom will be redundent
#5 shaddy
shaddy
  • 159 posts
Posted 30 November 2011 - 04:18 PM
thats helpful, maybe to some
#6 bourney
bourney
  • 137 posts
Posted 30 November 2011 - 08:50 PM
It will be easier if you start building the loom then come back with questions, if you stuck. Otherwise, without being sarcastic, about the most useful tip i could give is, use wire.....
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 November 2011 - 09:05 PM
I did this years ago - for a Rally car with all sorts of extras/fuses/light circuits. Just make a ladder drawing of what you need - and lay out the wiring! Obviously you will need a basic understanding of electrics or there may be trouble ahead. And decide if you are going to use different colour cables - or all same colour with numbers on the ends .........
#8 Jamie_hail
Jamie_hail
  • 555 posts
Posted 30 November 2011 - 09:21 PM
As said - just sit in your drivers seat with a notepad and tape measure, take notes of what needs wires, what doesn't. How long your runs are going to be ect. Then go inside and make up a ladder diagrem!
Easiest way to get all the wires to the rear for indicators, brake lights, tail lights, fuel pump ect is to use a 12/13 pin trailer wire, then just wire them in from the trailer wire, in the boot.
Cant help with the ecu, as I've not used a canems setup!
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 November 2011 - 10:22 PM
Good idea with that trailer multi-cable !
#10 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 01 December 2011 - 09:55 AM
Andrew,
Another recent(ish) post on a wiring loom. I added some links re wire types. No advice on how to do it though, it isn't a bad job but it can look like an bowl of spaghetti half way through, if none of my pointers re cables is any use do get some loom tape and cable colour markers.
http://www.theminifo...howtopic=207440
And yes, the trailer cable is a really good idea as loom taping (I didn't do my rear wiring) that long length would be a real pain and the trailer cable comes tubed already!
Charlie
#11 shaddy
shaddy
  • 159 posts
Posted 01 December 2011 - 01:30 PM
colour coded wiring i think will be best and it will be easier to trace in the future. going to start by drawing out what i think i need, then make a list of the parts i need.
#12 crock
crock
  • 91 posts
Posted 02 December 2011 - 06:12 AM
I have built wiring looms for 15+ British sports cars. It is too expensive to do the job right for a single car. By the time you buy all the different colored wires, the connectors, and the crimping/solder tools to do the job right it will cost you five times as much as purchasing a harness. You will have a MUCH better job done if you buy a harness premade from one of the specialist firms such as:
http://www.hotrodwires.com/
There are probably numerous firms in UK who offer similar packages. Try a google search. You will be much happier with the end result.
