Hi all,
My Mayfair 1985 1000cc has a definate tappet noise, I have adjusted them following the guide in miniworld but the noise is just the same. Speaking to a mate he reckons that the rockers could due to mileage (84k) be worn so when the tappets are set the feeler gauge is setng the tappets on the lip and not the camber (recess) as being worn in?
Is there another way to reset or is it best to replace the rockers?
Thanks BM
tappett setting
Big Man
, Jan 19 2007 02:11 PM
5 replies to this topic
Posted 19 January 2007 - 02:11 PM
Posted 19 January 2007 - 03:48 PM
Well I learnt to set my tappets from this book (plus the number guide in the Mini Haynes manual too) and my Mini has virtually gone around the clock:-
It's availble new from here:-
Mini Service & Repair Manual Link
But the tappet noise did get louder in my Mini after i'd fitted an ultimate engine steady to the thermostat housing.
Posted 19 January 2007 - 03:54 PM
New tappets or get a click adjust.
Before doing either of those take them off and see if there is a lip ! You 'might' be able to file it down
Posted 19 January 2007 - 04:16 PM
Any idea how much tappets cost? Also re filing is it as simple as it sounds?
Cheers BM
Posted 19 January 2007 - 05:18 PM
to be honest I dont know the answer to either ! Have a look on minispares for tappets (you could go second hand but then you might get the same issues).
You must be able to see the lip for it to have an effect in which case you could file it down but you would have to be dead accurate otherwise it would just make the problem worse.
Its worth trying before splashing out on a new set of arms though as a cheap fix
Posted 19 January 2007 - 07:01 PM
you can work with the wear u get in the rocker tip because it makes a nice cut out the same shape as the valve, as long as ur feeler gauge is the same diameter as the valve top (whch mine are)
the thing u cant compensate for easily is the wear in the bushes and the shaft!! maybe lift the back of the rocker when setting the gap, it seems a little backwards but try it!!
