The Mini is a Cooper Monte Carlo 1.3i (I assume an SPI).
We've having a couple of problems, but not sure if they're related or not. As such, I'll try and explain what's been happening since picking the car up on Saturday (3rd May)...
As a note, we know the car has a hole in the exhaust, somewhere...
We picked up the car on Saturday (nice sunny, hot day), and drove about 5 miles to fill up with fuel. Once full, we drove from Stoke-On-Trent to Loughborough (about 55 miles), down the A50 at 70mph. Everything was great, and we arrived in Loughborough!
At home, we couldn't not go out for a drive, so we pottered around in the car, and stopped off to show my bro and sis, and visit a local show. All stop starts, and no issues whatsoever!
On Sunday we drove from Loughborough to Walsall (about 50 miles), again at 70mph, with no problems. Coming off the A50, we drove past Tamworth towards the Walsall area. We went round the usual couple of roundabouts without problems, but the last roundabout we got to, the car died as we pulled away - I restarted the car, and it started first time with no spluttering etc!
Later on, we took a trip out to Kings Bromley (at this point it was a bit wet, but not raining), where the car again died when coming to stop at a roundabout - I noticed that the car seemed to cut out as I dipped the clutch to change down. It doesn't slowly die, it just goes completely without warning or spluttering etc, and isn't a user issue...! We drove back from Kings Bromley to Walsall, and it died a couple of times again.
In Walsall, we decided to change the K&N cone that the original owner had installed (without any cold air feed), to the standard air box (brand new filter inside), and attached the sensor etc.
We left Walsall to visit relatives in Edgbaston (approx. 17 miles) without any issues with the car (as far as I remember - at this point though, I was giving it a little more revs before coming to a slow / stop at roundabouts) - after the first 0.5 miles, we filled up with petrol.
When leaving Edgbaston to return to Loughborough, pulling off the drive the car had severe spluttering issues, which carried on all the way down the round, but I managed to "drive out of it", then it was fine.
Monday morning (weather nice and warm), I picked up some oil from Halfords (plan to do an oil change), filled up with fuel and added Wynns Fuel Injector Cleaner. We then drove to my parents (5 miles), without problems, and took my uncle for a spin whilst we were there - no problems!
Whilst I was there, we tried to locate a problem with the 4 front spots - none of them are working. We managed to get the two middle ones on (by doing nothing but check fuses and poking around), but the outer two aren't coming on at all. Then the middle two stopped working, so looks like a dodgy connection. Anyway, I also used Wynn's Intake Cleaner to clean the intake and throttle linkage etc, and gave it a bit of a spray whilst reving the intake open - it spluttered a bit, but carried on, and I left it running for a minute or so.
When setting off this evening, at about 19:30, the car again spluttered all the way down the round. Once at the bottom of the hill, I had to slow right down, and spluttered it out of the junction, only for it to die after about 5 metres - also found the indicators weren't working, so I must have knocked something...dipped lights etc are fine. At this point, I think the engine had become flooded - I had to plant my foot to the floor, whilst starting the engine, which made it burst into life after a couple of turns of the starter motor - lovely black smoke kicked out of the back, but assumed this was from the intake cleaner.
The car is now tucked up in my parents garage - drove fine when I turned it round and back up the road.
Tomorrow I plan to give it an oil change in the evening, and also locate a hole we have in the front of the exhaust - the black smoke above helped me locate where it was!
So, if anyone has any ideas on what's going on, and what to check for etc, that would be great! Like I said, I don't know much when it comes to working on engines, but hope to start here, and get my hands dirty big time!
Also, if anyone knows of any Mini enthusiast or specialist garage in the Loughborough area, that would be great - we'd like someone to give it a once over (mostly because of this problem), but also would be nice to have an expert at hand to assist
Thanks in advance to all who can help!
Cheers!
Edited by OJM, 05 May 2008 - 09:05 PM.
