Speaker Wiring Problem?
Posted 29 August 2008 - 04:06 PM
When I tried the drivers side speaker BY ITSELF it worked! As soon as the other one was plugged in all the sound went to it and none came from the drivers side speaker???
Is this something to do with the wiring to the speakers??? and has anyone got an idea how it can be fixed!
Posted 29 August 2008 - 05:14 PM
Posted 29 August 2008 - 05:26 PM
For reference the negative side on each speaker should have a trace (normally in black)
Posted 29 August 2008 - 06:04 PM
for a standaard ISO wiring harness the stereo wiring should look like this
cheers for that... i will have a look in the morning! it is an old head unit though and from what i remembered it looked a bit different from that
Posted 29 August 2008 - 11:48 PM
there isn't an ISO connector on the headunit and when I opened it up it looked a bit complicated, however nothing stands out as being wrong with the wiring...
Anyway suddenly an idea came to me! The headunit is a retro Harvard F980A and on the top it says:
Max output power - 2 x 6w
Impendance - 4ohms
Then I had a look at the speakers that had been put in and they were Goodmans CX12 with 12W RMS.
Therefore both speakers have a power of 24W but the headunit can only manage 12W
Is this the reason why the speaker works when plugged in by itself but as soon as the other is connected the first stops working?
Posted 30 August 2008 - 11:24 AM
Posted 30 August 2008 - 12:00 PM
I see your a fan of the Posh. Im from just outside Peterborough (little village called Maxey near Market deeping) if you get stuck you can pop round and il have a look for ya.
Are you in the Posh Mini Owners Club?
Posted 30 August 2008 - 01:56 PM
also take note of the wire size. the bigger you can run the better as alot of power can be wasted running too small.
Hope you get it going easily
Steve
Posted 30 August 2008 - 02:19 PM
going in a different direction here but are your speakers wired together? if so then the power may not be enough to power both speakers, i would check this out. I often think it is just easier to run new wires so that you know they are sound and not shorting anywhere.
Steve
yer well I am thinking of getting new headunit and speakers soon and by fixing it now I could just replace it with existing wires, but it now seems as if it will be easier just to get new speaker wires and starting again from scratch
Posted 30 August 2008 - 02:36 PM
if you have any questions then feel free to ask
Regards
Steve
Posted 30 August 2008 - 04:32 PM
Posted 30 August 2008 - 05:18 PM
You'll need the following bits to fit a Head unit aswel as the stereo and a pair of speakers.
Universal ISO wiring harness harness
Speaker cable (if your new speakers dont come with them)cable
Speaker terminal for above (again if your speakers dont come with any)crimp terminals
some heat shrink(this will be used to cover all the soldered joints)heat shrink
And for neatness and to make it look proffessional i always spray the crimp terminals with some satin black paint.
You'll also need to some basic hand tools to take the seats etc out so you an get under the carpet, a drill( to drill a hole in the rear seat backplate to pass the speaker cables through, thats if you mount them in the sae place)
I can sort out the crimping tool, soldering iron, electrical testers etc if you dont have any bits like this.
Things to consider;
where do you want to fit your speakers?
do you just want to renew the system and keep t simple?
or is it something you may want to expand on in the future?
Planning is the key
Posted 31 August 2008 - 04:08 PM
Things to consider;
Planning is the key
I'm going to have 2 new speakers under the rear seat connected to a new headunit.
So to start It is just renewing the old system and moving where the speakers are, however I may want to make it a more powerful system in the future.
Posted 31 August 2008 - 05:35 PM
Posted 01 September 2008 - 11:09 AM
This is what it looks like behind the headunit
will i need to buy a standard ISO harness and re wire it in to make it compatible with a new headunit?
