New Speedo / Dash
5 replies to this topic
#1 dan_w
dan_w
  • 152 posts
  • Local Club: Not yet!
Posted 30 August 2008 - 04:40 AM
When I brought my Mini it had the newer 3 dial dash, but I don’t really feel this fits in with the final look i want from the car once complete. I therefore wanted to change to one of the old Smiths centre dial speedos.
Fortunately managed to pickup an old smith’s speedo for the massive price of £5 and 2 oil pressure gauges at £1 each. What a barging.
Not knowing if the speedo worked and wanting to change it a little any way I decided I would fit the innards from the speedo that came in the car. This turned out to be a little harder than expected. Firstly I had to use part of the face due to the fact the mile counter is positioned under the centre on the newer dials. Then I realised the numbering did not quite line up.
This helped push me towards what I really wanted to do any way and that is to change the colour of the dial and change the font. After fitting the centre of the newer dial to the smiths and filling any joins I decided on silver. Its a little hard to see the actual colour because of the flash.
I think this will work great as I am planning on having my new dash black with the rails body coloured. The sliver should hopefully break it up a little.
The outer chrome polished up nicely and the black inner edge (just behind the glass) only needed a light sand and a coat of hammerite. Pic below shows the newer innards fitted to the Smiths casing.
I finally decided on a font for the numbering and have managed to line them all up missing all the holes for lights and still sitting in the right places. Just need to get the vinals cut for this during the coming week.
I used the 2 oil pressure gauges to house the petrol gauge and engine temp gauges from the original dash. Again I wanted something different so sprayed the outer frame of the oil pressure gauge silver and positioned the gauges behind these.
The biggest and most complicated job was to fabricate a wiring loom for the new dials. I wanted to replace the old bulbs with LED's. I have therefore users bright white led's to illuminate the dials. 1 in each of the small dials and 3 in the speedo. I have used yellow ones for the indicator lights and a blue for full beams. I then moved the petrol warning light and engine temp warning light to the 2 bottom lights in the speedo replacing them with red led's.
After lots of working out from the printed circuit board on the back of the original dials and loads of soldering I finally created the loom.
Lets just hope it works when wired up to the rest of the car.
Next thing to do is take a trip down the scrappy and see if I can find a decent digital clock to fill the space where the fuel gauge use to go in the smiths dial.
Once i get the vinals cut I will be able to finish fitting everything together and will update this with some finished pics.
#2 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 30 August 2008 - 08:03 PM
seems a great project :)
#3 Mini-Mad-Craig
Posted 30 August 2008 - 11:59 PM
Looks good to me buddy.
#4 MiNi2iNFiNiTi
MiNi2iNFiNiTi
  • 968 posts
  • Local Club: South Wales Mini's
Posted 31 August 2008 - 11:19 AM
This is exactly what I want to do in my mini, so I'll be giving my eyes on this thread :)
#5 Dirk130
Dirk130
  • 71 posts
Posted 04 September 2008 - 02:12 AM
or you could buy a complete convertions loom at one of the minishops :thumbsup: only that is not the fun is it....
#6 dan_w
dan_w
  • 152 posts
Posted 04 September 2008 - 02:25 AM
Yea i did consider that but I was not 100% convinced all the internals would be working when I brought the smiths dial. A lot of the internal parts were rusty and as you can see the glass was full of condensation. At least this way U know all the guages work. Fingers crossed all my wiring works. And like you said it's not half as fun.
No real update on this as i have been busy with other stuff and not got round to getting the vinal numbers cut
