My Car Keeps Stalling
4 replies to this topic
#1 sally the mini
sally the mini
  • 412 posts
Posted 04 September 2008 - 02:06 PM
ok i was driving in my car and when i come to a stop at a junction my mini (sally), her revs drop and she stalls the only way is to keep your foot on the accelerator and hope i thought it was because i had the heater on but i turned it off and it happened again
O and my clutch slips do i need a hole new clutch
thanks
scott
(trainee mecanic)
#2 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 04 September 2008 - 02:15 PM
Bad state of tune may lead to the problem of the revs dropping. Try some adjustments to the carb mixture screws.
#3 sally the mini
sally the mini
  • 412 posts
Posted 04 September 2008 - 02:20 PM
so is it serious or just a minor thing if so why did it hapen
#4 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 04 September 2008 - 02:28 PM
I wouldn't say its serious, check your air to fuel mixture, check your timing, is the gap right on the points check all these things and all the ignition components. As for your clutch it could be a single worn component i.e friction plate but you will be better to buy a kit and not just the single component.
hope that helps you a bit. :D
#5 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 05 September 2008 - 10:44 AM
moved to correct forum
