hi just pick up a engine today need to no what size it is engine number BHM1452F 153659 cheers craig
Engine Numbers
craig arc83
, Sep 04 2008 10:26 PM
4 replies to this topic
Posted 04 September 2008 - 10:26 PM
Posted 04 September 2008 - 10:27 PM
that strange, usually they start with 85 (850) 99 (998) 12 (1275) etc, have you tried googling it?
Posted 05 September 2008 - 06:41 AM
Wrong section - topic moved.
That isn't an A-Series engine number, whereabouts on the engine itself did you find that?
Posted 05 September 2008 - 10:26 AM
It's a factory recon (silver/gold seal) engine number....
Posted 05 September 2008 - 12:48 PM
Yep Guessworks is spot on cant find that exact number but a similar one
BHM1458 - Low compression piston, CAM6267 camshaft, late A+ cylinder head and crankshaft main bearings with centre locator tab, A+ block
BHM1460 - High compression press-fit wrist pin, CAM4717 camshaft, late A+ cylinder head and crankshaft main bearinfs with centre locator tab, A+ block
Not much help but i would guess it almost certainly an A+ 998
