Suspension Checklist
4 replies to this topic
#1 Hughes
Hughes
  • 377 posts
Posted 04 September 2008 - 11:02 PM
Gang!
Just want to double check ive got everything I need to sort the suspension on our 93 Italian Job. For info its got 13x7's and the suspension is completely standard. Its low mileage but has obviously been stood on its cones for years. Balljoints and track rods are sound. I am undecided as to whether to replace the cones or go the minitastic spring route so have left that out.
Minisport full poly bush kit + poly rebound buffer
Minispares kit of Gaz Lowered Dampers with Genuine Hi Lo's MSSK3001
Minispares Camber kit (Adjustable lower arms and tie bars MSSK3008
KAD Adjustable rear camber brakets
Will all be set up professionally - probably at Slark
Questions...
Are there any other pins bolts mounts etc worth changing seeing as its all coming apart?
With the 13" wheels im limited on lowering so do I actually need lowered shocks?
Is it worth doing the subframe mounts with poly or solid for 'hard road' use?
Sorry if this is covering old ground for a few of you but I cant find the exact answers im looking for.
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 05 September 2008 - 12:29 PM
I doubt you'd need lowered shocks, unless you're really dumping it?
Edited by taffy1967, 05 September 2008 - 12:30 PM.
#3 Hughes
Hughes
  • 377 posts
Posted 05 September 2008 - 01:55 PM
Thats exactly what I was thinking.
Im pretty limited on space with the 13" wheels anyway.
Anyone know if you can get a poly bush kit in Red?
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 05 September 2008 - 04:48 PM
I should think so?: -
http://www.superflex.co.uk/index.php
#5 Hughes
Hughes
  • 377 posts
Posted 05 September 2008 - 06:10 PM
Thanks Taffy!
Anyone got any thoughts on my other questions?
