New Door Card
18 replies to this topic
#1 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 09:26 AM
Hello People of the Styling part:D
I have had a little thought about door cards. I wanted something really simple e.g. blank, nothing on them, so I came up with the idea of getting some dark green acrylic and cutting out and copying the door cards I have already. That means just cutting holes for the handles, winder, lock etc.
What are your thoughts?? They are much appreciated and aren't just ignored.
Jack
#2 Mephiston
Mephiston
  • 386 posts
  • Local Club: London and Surrey
Posted 05 September 2008 - 10:20 AM
should look pretty good - and u can always put decals on them if u get bored and change them a bit without ruining them, i would be carefull when drilling the acrylic though - how anoying would it be to cut it out perfectly then crack it when you drill the holes :)
#3 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 10:34 AM
Cheers for the support Mephiston :)
Yeah I was thinking of putting something on them after I had made them and liked them :teehee:
Cheers again, I'll go and get some green acrylic from somewhere. Do you think B&Q will stock something like that??
#4 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 05 September 2008 - 10:35 AM
Acrylic would most likely rattle too much.
And if it's the same stuff we used in DT at school...personally I think it would look a bit naff!
#5 Mephiston
Mephiston
  • 386 posts
Posted 05 September 2008 - 10:40 AM
it depends on what kind you get - i dont know where to get it im afraid - but yes it probably would rattle so it maybe worth sticking some thin sound deddening or sticky back foam (sorta stuff used in a dash) to the back of it - facing into the door - that should reduce and possibly illiminate the rattleing
#6 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 10:44 AM
Well rattling could be a problem, but I'll sort it when it comes.
What stuff did you use at school??
Nevermind then :) Yeah as said above, I'll sort it when it happens.
#7 Ouster
Ouster
  • 2,986 posts
Posted 05 September 2008 - 11:12 AM
Just some standard acrylic sheet. Smelt horrible when you were cutting it with a bandsaw, and took ages to file down to get the edges smooth. Plus you'd need a very steady hand (or a laser cutter machine) to get the shape just right otherwise it'll look second rate.
#8 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 11:21 AM
Cheers for the warning, but I'll give it a shot :)
I'll come back with the results when there done.
When ever that is :teehee:
#9 miniEgg
miniEgg
  • 766 posts
  • Local Club: westcountryminis
Posted 05 September 2008 - 11:22 AM
think a handy thing when your drilling is tape on the surface, then dril through the tape. think that should stop cracking...
#10 Ethel
  • 26,580 posts
Posted 05 September 2008 - 11:27 AM
Polypropylene, find yourself some Foamex or Corriboard.
#11 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 11:30 AM
Any ideas as to what type of tape, or just duck tape or something??
Ok......
#12 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 02:45 PM
MiniEgg.......???? I'll just use any old random tape I can find :)
Ethel, any ideas where I could get some of this stuff from, I'm still looking at the Green Acrylic as I think it will look smart, when done and correctly done.
Cheers to the both of you.
#13 Retro_10s
Retro_10s
    Moderator
  • 10,176 posts
Posted 05 September 2008 - 03:56 PM
gonna scratch like a ******* though in everday use!!
#14 captainjack15
captainjack15
  • 3,925 posts
Posted 05 September 2008 - 04:04 PM
Hmm didn't think of that :thumbsup:
#15 fergie
fergie
  • 369 posts
Posted 06 September 2008 - 08:06 PM
hi there i own my own company and my sole business is perspex i have evey colour every thickness so if any body is looking for some i can sort them out..
you have to buy it in 3m x 2m sheets but i already hold a massive stock....
if there is a few people looking for them i would be willing to make templates and set up for making them...
cheers.....
