My guess is..perhaps the temp guage is wrong? No overheat steam fron under the bonnet as tomsbluemini was in front and rosewhite was looking from their car to see if the overflow was leaking out...nothing. I have replaced the thermostat,thermostat housing,water pump ,and the all hoses and she is not loosing coolant anywhere. No water in the oil showing signs of head gasket issues...so what is the likely culprit?
On shorter drives to and from work,about 7 miles she's just fine temp guage wise...any Idea's? I know mini's run hot anyway but this seems a bit extreme. What should the water temp be on a warmed up 998 anyway? Just curious.
Thanks for any help,I appreciate it.-Andy
Model: city
Year:1987
Description of problem (please be as in depth as possible):see above
Any non-standard parts that might be involved with the problem?none!
Edited by landy andy, 05 September 2008 - 09:37 AM.
