Which Inlet Do I Need?
7 replies to this topic
#1 burnerking
burnerking
  • 173 posts
Posted 05 September 2008 - 09:46 AM
998 cc Mayfair
1987
As the title says, what inlet do I need to complete my set up? Also, do I need to change my needle?
Thank you for your help
#2 Mephiston
Mephiston
  • 386 posts
  • Local Club: London and Surrey
Posted 05 September 2008 - 09:50 AM
any of the widly availbile heated inlet manifolds should work with your set up - you will probably need a need change but the only way to get that right is to get it rolling roaded - if you add something like a k+n performance air filter you will have basicly a stage one kit
http://www.minispare....aspx?pid=35083
thats an example of one that would work
#3 burnerking
burnerking
  • 173 posts
Posted 05 September 2008 - 10:00 AM
Cheers.
I have just got a 2nd hand k&n filter - I've slowly bought a stage one kit. I'll get it on a rolling road soon then.
Can you buy new filters for the K&N filter?
#4 Mephiston
Mephiston
  • 386 posts
Posted 05 September 2008 - 10:03 AM
basicly thier meant to be lifetime filters so u dont have to replace them- but its good to clean them every few years with a special oil they sell - im not sure how much it costs - but im sure demontweeks sells it - but it may be worth looking around for a new one as there not too expensive - i presume u have a cone one - i have an element one but cleaning them in principle is the same i believe
#5 burnerking
burnerking
  • 173 posts
Posted 05 September 2008 - 10:09 AM
I thought that you know, they look sealed on. Yeah I have a cone one for HS4 carbs.
#6 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 05 September 2008 - 10:11 AM
You don`t use the oil to clean them that is used after you have cleaned the filter to trap the dust particiles. You need to use K&N cleaning fluid first!
#7 Mephiston
Mephiston
  • 386 posts
Posted 05 September 2008 - 10:13 AM
my bad - i thought that was the case but i was sure if you just oiled them -- sorry
#8 burnerking
burnerking
  • 173 posts
Posted 05 September 2008 - 10:23 AM
All good though, thanks for the info
