Urgent Help Please!
NETTY
, Sep 05 2008 01:43 PM
9 replies to this topic
Posted 05 September 2008 - 01:43 PM
1989 MINI CITY E
Becky happily driving along, thinks she heard something drop off car, then car wont go into gears, just into first gear....cant telly ou anymore than that because shes being towed to the garage, any suggestions on first impression please!
Posted 05 September 2008 - 01:54 PM
Pin has partially/fully dropped out of the gear selector rods. Dead easy 2 min fix.
Posted 05 September 2008 - 02:12 PM
just been out garage and he said its an engine mounting come loose and the engines moving when shes changing gear and shorting out the alternator?????
Posted 05 September 2008 - 03:03 PM
Even if that's true, the car should still go into gear.
As said above it's probably the gear selector pin.
Posted 05 September 2008 - 03:06 PM
car goes into gear, just drove it back, very slowly.....engine mounting, got some from local motor factors, how hard is it to do>??
??? That doesn't make much sense. Ok engine mount undone, but shorting the alternator? On what?
It'd explain the difficulties with the gearchange tho'.
Posted 05 September 2008 - 03:08 PM
was this a mini friendly garage or just one out to make some money ?
Posted 05 September 2008 - 03:12 PM
Top engine steady (dogbone thing) dead easy, just replace the rubbers and refit.
Bottom engine ones like yoga for fingers. disconnect top dogbone. Disconnect any engine steadies under the engine (there are many types front and back) Jack up front of car then put on axle stands, then put jack under engine and lift just a little. Dislocate all fingers on right hand and undo the 2 bolts on the subframe and the 3 on the gearbox and clutch housing. Replace mounts. Replace fingers.
Posted 05 September 2008 - 03:19 PM
Posted 05 September 2008 - 03:24 PM
hiya thanks for help, the garage is the place where I work and they havent tried fixing it or anything but i dont know what he meant that the engine was shorting the alternator (causing cut out) but beckys 17, jsut passed test and I think that shes just got panicky and stalled it several times because I drove it back and it was ok, going slowly. going to get some engine mounts now and will let you all know, butthankyou for the info....
all the best,
Thanks!
all the best,
Thanks!
