8 Port Build - What Capacity?
Posted 17 October 2008 - 07:31 PM
I am at a ongoing restoration of my Mk1 Cooper S 1071cc for which I would like to have an 8 port engine built. It will be a BRG circuit racer look a like (H65)
Now the questions:
- I have a Mowog 8 port head fully reconditioned by Avonbar Racing and ready to go.
- 2 Weber 40 which I think wont fit under the bonnet, so maybe I have to go the Amal route - need advice here.
- What would work best? Use the original 1071 block and keep it according to the car? or wil the head demand for a bigger capacity block? - I need advice here too.
I have been told that small bores and 8 port are very disapointing on the torque. Amals can be a pain to tune and also provide dificult start up because ther is no choke. Fuel injection costs a fortune.
What would you recomend me to do. Please advise the right engine builder to do a good job within reasonable costs.
I appreciate any advice.
Kind regards,
Rui
Posted 18 October 2008 - 06:03 PM
i would think that your 40's are going to be huge on a 1071 too, have you considered going to newer bike carbs, im also going down this route, i would love amals, but as you say no choke is never a good thing for starting!
Posted 18 October 2008 - 06:04 PM
Posted 18 October 2008 - 06:11 PM
Hi all,
Now the questions:
Kind regards,
Rui
You have 70mm bores with the S engine overboring a 1071 would be a crime!
can not say about bike carbs but Bill Richards in kent would be better at what would work on that head you have, amals cost a bomb as well but a kugelfischer pump of a puegoet or BMW will fit and work that engine.
Posted 18 October 2008 - 09:07 PM
Thanks for the reply.
For now the only option I have that actually fit under the round nose bonnet are a set of four Kawasaki carbs. They are Keihins, I think 32mm choke.
I believe 1071cc with this head could make a very interesting engine, lots of revs. But i really would like to keep all the setup period to go well with the car.
Is there anyone around that has done this kind of setup? I basically need some benchmarking.
Will post some photos of the head soon.
Regards,
Edited by rdma, 18 October 2008 - 09:07 PM.
Posted 18 October 2008 - 10:07 PM
What you say about torque is right, but a short stroker is never going to have the torque of a long stroker. The 8 port will be better than the 7 port at helping the situation due to the better inlets, but it will never be great. If its something your set on doing, and considering you have the parts, i would, speak to people who have good experiance with the 8 port, people like Bill Richards and MED and speak to Swifty too, i dont know what he's like on 8-ports but he used to do a lot of 7-ports as-well as formula junior racers (which have 1071 based engines)
Posted 18 October 2008 - 11:08 PM
I've read about that 999 8 port mini you refer too. I have a 970 S mk1 and for once though I could go that route, but I don't really think I will get my hands on a Tecallamit Jackson Mechanical Injection ou a Lucas one. The are far too rare and expensive when available.
Regards,
Rui
Edited by rdma, 18 October 2008 - 11:09 PM.
Posted 19 October 2008 - 12:06 AM
Posted 19 October 2008 - 07:55 AM
As for carb setup, I think the Webers would be awesome, but there are loads of bike carbs that would probably be a good option, maybe even go for TB's of something like a Gixxer 600 or something? Then go for mappable ignition and injection. I guess it depends on how 'historic' you want to be really.
Posted 19 October 2008 - 09:53 AM
Posted 19 October 2008 - 06:09 PM
hmm thats why I said get a kugelfischer from a BMW or puegoet! it some what cheaper and its machanical and better than lucas! I have run a mini with this pump and barrel throttle bodies very cool!!Thank Jetblick for your input.
Regards,
Rui
Posted 12 December 2009 - 12:50 AM
I have bought a 7 port head from ken elder in australia and want to ensure that i do not have to modify the bonnet to make it fit. Did you manage to install the bike carbies(keihins) and have them fit under the bonnet whilst using air filters? If so, how so and do you have any advice/pictures ?
Paul
