I am currently restoring a 1964 mini 850, replaced quite a few panels on it already, and i now need to repair the inner wing panel so i can then fit the new inner and outer sills (and doorsteps!).....both sides.
So the guy who put the last replacement ones on had managed to cut out the part of the inner wing behind the inner A panel, then he welded a strip of metal along the edge of the inner A panel and the inner wing to somehow hold it altogether - this has not really helped me in knowing what was originally there!
I have cut out that part of the inner wing and the A panels, Mini Machine dont make a Mk1 inner wing repair panel, they said to use a Mk3 one and modify it.
So i have lined up the Mk3 inner repair panel, and it seems to fit fine, but it has a folded edged which runs vertically with the door post.
Does this edge get welded to the door post? or should i do anything else with it?
in the photos below i have clamped the repair panel in place, then i have clamped the A panels in place over the top, and then i roughly put the door in place and it does all seem to line up roughly. I am not going to fit the A panels yet, its just this inner wing panel i am going to do for now as the doors need reskinning first.
Am i along the right lines with this? or is there some great way of doing this which makes more sense!
hopefully the pictures will come out below and show what i mean!
Thanks for your time
Jamie
