I'm interested in this as well because I'm looking for a rear subby for my Mk2 (going dry)
I thought the dry rear subbys were similar until '91 where they had bits for the exhaust added (hangers). Although I have heard about the change you mention in '76
I know you can buy a early bolt and bush kit from Minispares
Linky...
So maybe you could buy that set to fit the rear subframe as it were pre '76?
Does anyone know if this kit can be used on the new non gen rear subframes which are the pre '91 spec?
I think if you use the old trunnions from the subframe which came off the car you should be okay?!
Edit a bit of research on Minispares
This seems to be the pre '76 trunnion which holds the two bushes
and this one the '76 onwards which as you can see has a larger hole for a bigger bush and is strenghened
I think you could use either trunnion if you have the right bushes to go with it
I think I may have answered some of my own questions here
Edited by GreaseMonkey, 18 July 2009 - 05:48 PM.
