1275 Austin Mini Cutting Out When Cuming To A Stop
Posted 07 March 2010 - 11:38 PM
Year:1986
Description of problem :Hello everyone my mini keeps cutting out when she is cuming to a stop and the only way to stop it cutting out is to pull the choke out at every junction and roundabout any ideas what could be wrong with it
Any non-standard parts that might be involved with the problem?
SINGLE HIF44 CARB & K&N FILTER
Posted 07 March 2010 - 11:39 PM
have you put some oil in it recently?
Posted 07 March 2010 - 11:42 PM
Posted 07 March 2010 - 11:45 PM
Posted 08 March 2010 - 12:54 AM
If theyre black and sooty, it would indicate your car is running too rich. If it's running too lean there'll be a white-ish coating I believe (although don't quote me on that!).
Also might be worth checking the timing if you have a stroboscopic timing light.
Chris
Posted 08 March 2010 - 10:59 AM
Posted 08 March 2010 - 07:34 PM
Posted 08 March 2010 - 07:45 PM
what i did was clean the plugs, clean the air filter and there was some dirt in one of the pipes leading to the fuel pot by the carb so i had to pull the pipe off and lid off and blow down the tube, if this is the case, get a fuel filter then this will never happen again
Posted 08 March 2010 - 08:06 PM
I do no what i am doing with engines and carbs just motorbike ones lol cars are all new to me ;-}
Posted 08 March 2010 - 08:19 PM
Tom
I did de-coke the engine about 200 miles ago when i changed the head gasket, i think that the carb and timing has been played with to compensate for a blowing head gasket and the amount of carbon build up. I do think that it is the idle mixture and timing that needs adjusting.
Posted 08 March 2010 - 08:21 PM
Posted 08 March 2010 - 08:28 PM
Thanks everyone
Nikki
