Some of you may know I'm dropping a '99 MPi engine/box into an older car...However I'm finding problems with the new engine and want some of your learned opinions on where to go next...I bought it not knowing any history on it and just accepted the risk it could be a duffer, I rather hoped it wouldn't be though!
Dash shows about 45k. Engine was grubby as hell so stripped off all ancillaries and pulled the head to give it a clean and check over.
Immediately suspected a blown head gasket as there was oil seeping from the block-head interface behind the manifolds...also plenty of brown scunge in the header tank which I really should have spotted before...once in the head I found ALL valves and guides need replacing (stem diameters worn), especially the exhausts, and the seats look more pitted than I would have expected...which all surprised me at 45k and got me curious about the rest of the engine
I then took the flywheel cover off to discover a liberal coating of oil all over the clutch. "Oil seal's gone" I thought, which again surprised me at 45k.... so I pulled the flywheel and primary gear to discover that the front primary gear bush has gone and
Now slightly annoyed, I measured the crank axial float - if this was too great then I would have started digging further...however, it's about 60 microns so appears fine...Other than this the only things that makes me believe that this has done 45k not 145k is that there are still the factory honing marks in the bores, the bodywork on the car was pretty good and the compression figures were apparently up at the 15 bar mark
So...any rules of thumb here? If the head's so worn and the primary gear needs a refurb then is there anything else I can expect to be shafted ? Does what I've described tell a nasty tale - such as being run with no oil? Or is this much wear on these bits normal at this mileage for this engine and other bits are probably fine? I guess one of the worrying things for me is that I simply don't understand the loading condition that causes the front primary gear bush to twist like that without it seriously binding up on the crank...
to be honest I don't have a clean enough garage to contemplate an engine rebuild ATM so would likely be on the hunt for another engine and box!!
Thanks!
Al
