Its a 1984 with a 1380cc.
Just before it broke it smoked a bit under load. When it did break a lot of smoke came out the exhaust and there was oil all over the engine and some on the floor.
I did a compression test across the cylinders. From cylinder 1 to 4 it was 180, 70, 65, 50.
Ive now taken the cylinder head off to find the gasket is broken between 2 and 3. Is there something else broken because the pistons look quite black in 2 and 3 and also on the head.
Please look at the pics and see what you think. Thanks
