Wont Run Without Choke On What Do I Do
Posted 04 September 2010 - 09:30 AM
Posted 04 September 2010 - 09:32 AM
Posted 05 September 2010 - 05:07 PM
Posted 05 September 2010 - 05:09 PM
Posted 05 September 2010 - 05:56 PM
If it drive crap but idles fine then its probably new needle time.
Posted 05 September 2010 - 08:52 PM
Posted 05 September 2010 - 09:06 PM
Posted 05 September 2010 - 09:07 PM
You will then need to reset the choke settings aswell after.
Posted 06 September 2010 - 06:54 AM
Posted 07 September 2010 - 02:55 AM
hi guys got my mini all back together and it runs quite well but when i take the choke of it slowly dies
why is this
it hasnt been running for a year and the carbs been stripped down
what needle do i have to asjust
thanks
ross
If I understand you correctly you have done "something" to your engine and you or someone else has done something to the carburetor. Is this correct?
What was done to the carburetor? When the carburetor was placed back on the engine did you go through the basic adjustments to reset the starting mixture, idle, fast idle, and choke?
When the carburetor and engine were worked on, was the manifold removed? If it was, did you make sure it was seated properly when refitted to the head? If you have a brake servo, did you make sure the vacuum hose between the manifold and the servo was fitted?
