Please Help, Can't Get Swivel Hub Off Driveshaft :(
Posted 04 September 2010 - 10:52 PM
Oh by the way I have a 2001 Cooper
Thanks guys,
Connor,
Posted 04 September 2010 - 11:04 PM
Posted 04 September 2010 - 11:12 PM
Posted 04 September 2010 - 11:32 PM
Posted 05 September 2010 - 10:01 AM
Clever!! I like that idea..It might not be an option but if you can manoeuvre the car next to a solid wall you could pop the hub back on the car and push the CV with a jack. Or take the hub to somewhere with a hydraulic press.
Posted 05 September 2010 - 05:22 PM
Posted 08 September 2010 - 10:38 AM
Posted 08 September 2010 - 11:50 AM
The legs hook around something like the disk or the hub, If you do it on the disk you will probably have to replace the disk afterwards. With these in place the big bolt in the middle winds down onto the end of the drive shaft, therefore pressing the drive shaft out of the hub. Watch out because after you have wound this in a few turns the hub and shaft will be under a lot of presure. You would be best off winding the nut down so it is just tight, then turn it another 1 full turn. Tap it with a hammer and leave it for 10 minutes. Then wind it in one more turn and do the same. Eventually it will come out.
Greg H
Posted 08 September 2010 - 12:12 PM
Posted 08 September 2010 - 12:13 PM
