Rev Counter Light Not Working - Rev Needle Still Works
3 replies to this topic
#1 Daveymo
Daveymo
  • 53 posts
Posted 06 September 2010 - 01:32 PM
Model:Mini Cooper Spi
Year:1993
Description of problem: Rev counter LIGHT not working. Rev counter needle still works as normal
Hi guys.
As above, our rev counter is playing up a little bit.
We currently have the 3 dial dash and the light behind the rev counter isn't working, but the rev needle does work as normal when engine is revved.
I'm guessing it's likely to be a bulb or is it more possible it's just a loose wire?
(before I go butchering and ripping the dash apart by accident)
Also any help on how to remove dials safely would be great
Cheers in advance for any help given.
Davey
:D
#2 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 06 September 2010 - 01:39 PM
Bulb, as they are all connected via the printed panel on the back of the dials and supplied by the same circuit and wire if all the other lights work then its the bulb thats gone or worked itself loose.
#3 Daveymo
Daveymo
  • 53 posts
Posted 06 September 2010 - 01:57 PM
Brill thanks Joshua
Yep, forgot to mention that other two dials work and light up as they should.
Newbie Question No.2..... Anybody know the bulb model number?
Is it a 501 or a w5w bulb or something like that? Just means I can buy one tonight then, remove and fit it all at once if neccessary
#4 Daveymo
Daveymo
  • 53 posts
Posted 07 September 2010 - 12:09 PM
anyone?
