Removing My Dash Rail
16 replies to this topic
#1 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 06 September 2010 - 01:33 PM
hiya has anybody got a step by step quide of removing top and bottom dash rails
thanks danny
#2 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 06 September 2010 - 01:37 PM
Tot pail is held on by 3 nuts
#3 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 06 September 2010 - 01:38 PM
is it that simple lol do i just need to take my dash out then undo bolts and pull off ??
#4 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 06 September 2010 - 08:34 PM
anyone ???
dont want to break something
#5 DanNomNom
DanNomNom
  • 165 posts
Posted 06 September 2010 - 09:10 PM
I did this today after reading this thread,
It is that simple, you have to undo the nuts, but the bolt is welded onto the rail, so you kinda have to hit it up then pull it towards the seats.
However, mine doesn't have a middle bolt, the previous owner has chopped it off. I'm not sure how easy it would be to get the rail high enough to clear the hole before it hits the windscreen (if that makes sense).
It just took mine a whack upwards at both ends then it came out :P
I can take pictures of the bolts if it helps.
#6 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 07 September 2010 - 08:34 AM
thanks for the reply do i need to take out the switch panel and remove choke cable and heater cable as i dont relly want to be undoing the coke cable as i just seem not to be able to reattch it lol
#7 E-Tizzle
E-Tizzle
  • 901 posts
  • Local Club: Essex Mini Club
Posted 07 September 2010 - 08:38 AM
no, bottom one just slides off, what you need to do it remove all of the little clips that hold the vinyl on.
i think there are about 8 ish, then there will be a chrome strip on the back (possibly) take that off.
then you just have to lever the foam around the switch panel, then the whole thing just falls off.
elliot
#8 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 07 September 2010 - 08:39 AM
elliot
ok many thanks i need to send them off to retro retrims for recoving from what i can make out it comes off in 2 pieces ?
#9 E-Tizzle
E-Tizzle
  • 901 posts
Posted 07 September 2010 - 08:52 AM
what the bottom one? no thats just one piece i think ive got some pictures somewhere
#10 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 07 September 2010 - 08:53 AM
yep the bottom one im taking both off if you have pics of both that would be good
thanks danny
#11 E-Tizzle
E-Tizzle
  • 901 posts
Posted 07 September 2010 - 09:04 AM
i havent got one of the bottom removed for some reason.
#12 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 07 September 2010 - 09:06 AM
thanks can i just fix dashboard back on while ive sent off my dash rails ???
#13 E-Tizzle
E-Tizzle
  • 901 posts
Posted 07 September 2010 - 09:28 AM
my one is held on with 3 metal ( [ )of them <<, they hook inside the rails so you might not, but you might be able to so best have a look/
#14 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 07 September 2010 - 09:29 AM
yh mine is held on by them so thats ok to bolt it back on ??
#15 minbin2010
minbin2010
  • 141 posts
Posted 07 September 2010 - 09:43 AM
does eny one have a center peice of a dash for 2 clocks i need 1 n on the top rail my bolts wasnt welded on mine just unbolted n came straight off the bottom 1 wasnt as easy i ended up gettin arcey then ripped it off because i wanted a new 1 eny way lol
