649 Camshaft (also Known As Aea648/649)
Posted 07 September 2010 - 08:19 PM
So my question is has anyone had any experience with a 649 (genuine AEA648/649) cam in a similar sort of engine, they were designed for the small bore engines so should give good power albeit rather lumpy up to 2500-3000rpm. I also have been informed i would need to change my oil pump drive from my 1985 metro engine (according to the guessworks site) to a pin drive type to run this sort of a cam?
Many thanks, Evan.
Posted 07 September 2010 - 08:24 PM
ive driven a car with a piper 649+ in, and it is a great cam, albeit a bit of a crap idle, not that it should be let to idle, but you know about it when it gets on cam, lol
why do you want to go for the "genuine" one? the piper version is so much better and more accurate due to modern machines, as well as developing more power.
also the engine would struggle to breath properly on 1 1/4's.
Edited by samsfern, 07 September 2010 - 08:31 PM.
Posted 07 September 2010 - 08:34 PM
Evan.
Posted 07 September 2010 - 08:37 PM
Edited by samsfern, 07 September 2010 - 08:39 PM.
Posted 07 September 2010 - 08:44 PM
Posted 07 September 2010 - 08:51 PM
its was a great cam and yea you do have to run a different oil pump,easy to get tho
Posted 07 September 2010 - 08:53 PM
Thanks for the help, i'll keep an eye out for some 1 1/2" SU's then. How long until your 1330 is built an running. Is it safe/reliable to run as high compressions ratio as you will be, i thought the norm was in the region of 10.5:1 ?
i managed to finish timing the cam in today, got it absolutely spot on, took ages and a few attempts, but as its in bits why not get it spot on. so thats the bottom end finished today, ive got a classic car show im going to be attending on the 12th, so it will be coming apart the weekend after that, and im going to ditch some weight, keep an eye out for my project thread when i open one. ive set myself a target, Run what ya brung @ santa pod on the 31st october, hopefully ill be able to get into 16's instead of crawling up there in 18.2 like i did at mini in the park, but it should be done well before then.
as for reliability, it shouldnt be a problem, i used to run 11.5:1 on my old mini, that i rolled, used it everyday with no problems. just need to use high octane fuel, like shell v-power or bp ultimate, i will also be using an octane booster additive to raise the octane to about 102, this is to prevent detonation. i admit, it may be a bit of a sod if you intend togo to shops in it (my mums cars for that, lol) or if you get stuck in traffic, but ill just have to see how i get on with it, should be fine.
Edited by samsfern, 07 September 2010 - 08:56 PM.
Posted 07 September 2010 - 08:55 PM
ive got a old 649 cam that i had in my 1275 with a large valve head and a single 45 last year ,just have too collect it from SRE as i 4 got it wen i collected the engine,only changed it due to building a complete new engine
Do you know who the cam is produced by or is it the genuine 649 one?
Also how was it to drive in you 1275, was it quicker than a bog standard 1275 as i'm hoping to see a power increase to keep up with my mates cars
Posted 07 September 2010 - 09:03 PM
Exactly why not get the timing spot on while you can while the engine is out. 16's seems very reasonable. I timed my mini 1275 0-60mph not sure how acurate the timer was but managed 13 seconds so your car seems very quick so my 1/4 mile time would probably be embarassing. It would be great if you could let me know how yours performs as i don't think i will have started to build mine by October as its my daily runner at the moment.
I used to run my slightly modified 998 on shell V power and it made a noticeable difference performance wise.
Posted 07 September 2010 - 09:07 PM
Edited by samsfern, 07 September 2010 - 09:12 PM.
Posted 07 September 2010 - 09:10 PM
as for power it was 93bhp but the rings were shot and compression loss on 2 cylinders.it was standerd 1275 bottom end with the cam,
14cc mini 7 race head and weber 45,
the compression was way too high but it went very well,come on cam around 3 all the way to 6500-6800ish
tick over was a problem but that was down to the head and just worn out rings,a friends got the 649+ in a 1330 too and that ticks over perfect really (lumpy as u would expect) fine on the road for daily driving too
Posted 07 September 2010 - 09:15 PM
its stamped aeg 649 inbetween the lobes and the dizzy drive as far as i can remember,
Pretty damn good performance figures for a 1275. Just out of interest, how much would you be willing to sell the cam for?
I don't mind lumpy tickovers as it sounds as if you have a beast of an engine under the bonnet and its good to know it should perform reasonably for a daily drive.
Edited by 1977 Loud_Mini, 07 September 2010 - 09:16 PM.
Posted 07 September 2010 - 09:19 PM
thats my problem, mines the daily user, its just having the time to take it off the road for a few weeks, as i want to paint in the engine bay, relocate oil cooler, rewire the car, etc, and the insurance has run out on my other car, cant afford 1500 to insure it, and id rather sell it and spend the money on the mini. and i cant face having to pushbike to train station everyday to go to work, i love driving the mini, lol
I think everyone who owns a mini likes driving them, i know i do. My money has all gone into my mini getting it to look as near to a rally car on the outside as i can get it. Now its just the engine i need to do so that i can have the performance to go with the looks
Posted 07 September 2010 - 09:21 PM
Edited by samsfern, 07 September 2010 - 09:22 PM.
Posted 07 September 2010 - 09:22 PM
well first i collect it from slarks as im there on the 18th sept,check it over,im sure its still be fine but i paid £70 2 years ago so £30 +postage or i be at castle combe action day and i bring it there
